update
Andy335Touring
Post Fri Aug 26, 2005 8:59 pm
Do know which ignition circuits go to which pair of cylinders ?
M20 and M30 are the same firing order so mine should be the same as yours i think ?
Sorry for all the questions, you have been a big help to me thanks ;-)
lentec
Boost Junkie
Post Fri Aug 26, 2005 10:05 pm
No problem mate :cool:
ignition driver 1 goes to coil 1 for plugs 1 and 6
ignition driver 2 goes to coil 2 for plugs 2 and 5
ignition driver 3 goes to coil 3 for plugs 3 and 4
you dont use the main relay driver as in direct to ignition switch/main relay instead
Andy335Touring
Post Fri Aug 26, 2005 10:28 pm
lentec wrote: ignition driver 1 goes to coil 1 for plugs 1 and 6
Ah, same pattern as the injectors
Sorry if i am being thick but i don't know if i understand what you mean ?
If pin 4 is coil driver 3 and connects to the coil what do you use to trigger the relay ?
I've probobly got the wrong end of the stick though :oops:
lentec
Boost Junkie
Post Fri Aug 26, 2005 11:26 pm
The key switch ignition live! thats what ive done anyway
Andy335Touring
Post Fri Aug 26, 2005 11:43 pm
Ah right, so you don't have a main relay you use the 12v + from the ignition switch to pins 11 + 28 ?
It's been a long time since i wired mine up. I think i have three relays,main relay,fuel pump relay and injectors/coil relay.
Time for bed,i'm knackered ! :mad:
lentec
Boost Junkie
Post Sat Aug 27, 2005 8:17 am
Ive got 4 relays main engine, coils and injectors, fuel pump, supercharger!
wired so the main powers up everything else.
jmc330i
Post Sat Aug 27, 2005 11:10 am
Andy335Touring wrote:James, thats well cheap ! So long as i can get the Emerald OS loaded on to it and it has the 9 pin connector for the serial cable i'm not bothered what else its got feature wise.
Is this the one ?
http://www.woolworths.co.uk/wwstore/pro ... op=details
That looks like it mate, although he only paid Ԛ£349 about 4-5weeks ago so maybe theyve put the price up since.
I know they were also selling it at Ԛ£449 with a digi camera and some other stuff, but my mate just wanted the basic lap top.
I cant remember if its got a serial port, but that lead lentec posted will do the trick. Its got 4 USB 2.0 ports, but 2 are needed for the external CD writer.
Still, it does everything my mate wanted and isnt a bad spec either.
James
'91 325i Sport
'93 318i touring 16v
Turbo-Brown
Boost Junkie
Post Sat Aug 27, 2005 8:36 pm
Yip do!
More progress, got some injectors mounted :)
e30_Turbo
Boost Junkie
Post Sat Aug 27, 2005 8:39 pm
Todays update
Well, started well, was up an hour late :cry: , arrived in Kent at aprox 1030 and got started. First off we made up the charge pipes, fitted air temp sensor, welded 90 degree bend, fitted dump valve and fitted all in from the intercooler back.
The coolant temp sensor was rethread, hole tapped and sensor fitted. Manage to finish all the wiring, checked and double checked. Then onto the fun part, dummy fitted manifold and downpipes, spot welded before proper welding was done. Only hitch we ran out of welding gas 10 mins from completion :eek: , but that'll be sorted in the morning.
So just MS to get working and a few nuts and bolts and we're there.
Fingers crossed all will be well and I will be joining FI bmw crew by lunch tomorrow.
Now off for some food, rest and sleep before we start again.
I have loads of pics, most of Ant being silly with pieces of pipe, so will post when I get home Monday.
More info as it happens!
Widge
Post Sat Aug 27, 2005 9:27 pm
Good stuff mate! Fingers crossed for tomorrow - FI here you come!
Looking forward to pics.
Jon_Bmw
Dangerous when thinking
Post Sun Aug 28, 2005 10:48 am
Nice alex, those throttle bodies are coming together real nice.
Well done Mark and Ant, sounds like you arn't to far away from being done now, please triple check things, i'm sure you will. Can't wait to see some more pictures of m20 turbos, it keeps giving me idea, which unfortunatly cost Ԛ£Ã”šÃ‚£Ãƒ”šÃ‚£Ãƒ”šÃ‚£'s.
Something i did and you might want to do is check the oil pressure to the turbo and check the flow rate by disconecting the return for a second and cranking it with a suitable container underneath. Then its a bit of guess work, but it seemed about right to me. You don't wanna blow the oil seals.
Also check for fuel leaks from wherever you have changed things, injectors, fuel regulator etc.
Big respect to you both :cool:
Jon
lentec
Boost Junkie
Post Sun Aug 28, 2005 11:33 am
alex that looks the knuts mate! nice one 8)
mark and ant good to hear its goin well! hope you guys have better luck than i have :(
Its all gone wobbly this end guys :(
looks like my recent oil issues or lack of has done some damage after all.
So on hold till tuesday unless anyone on here has a spare set of rockershafts/rockers gettin in the way?
As mine have worn ovals thus it sounds like someones thrown a bag of nails in the cover DOH!
The s/c roters wernt as bad as i first thought tho 8)
but the pully has somehow come off center and started wobbling so gonna have a go at re centering it today as soon as i can feel my knuckles again :wink:
e30_Turbo
Boost Junkie
Post Sun Aug 28, 2005 11:23 pm
Done
More details to follow, need a shower, 9hrs sleep and some food.
Had a quick test run, can say for sure the dump valve works :D
Pics asap.
Mark.
(Just to explain I would not have finished this on my own in a month of sundays, Ant has advised, welded, grinded me to where I am. Thankyou very much Ant. :D )
Long live the twin red e30 Turbo's :D
Sooty
Post Mon Aug 29, 2005 12:05 am
:woohoo: :clap: :thumb: :clap: :woohoo:
SLEEP?
Never mind bloody sleep.......tell us how it went!!!!!!!!!!!!!!!! :D
BTW - Congratulations & well done guys. Look forward to seeing it in the flesh next time we meet up Fozzy.
Andy335Touring
Post Mon Aug 29, 2005 1:00 am
Nice one Mark ! :woohoo:
Oh yeah and.................
:ttiwwp:
Widge
Post Mon Aug 29, 2005 1:07 am
All good things come to those who wait :roll: :x :oops: :cry: I can't wait :lol:
glenn
Engine Transplant Services
Post Mon Aug 29, 2005 9:22 am
well done mark and big up to ant.
really pleased for you.
cant wait to see and hear these blown m20's.
it's great when a project hit's the road.
have fun!!
:drive: :drive: :drive:
Ant
Retired Team Member
Retired Team Member
Post Mon Aug 29, 2005 12:30 pm
Cheers all for the props..
Mark is now on his way home, we had a good laugh in the end, job done in the weekend is pretty good going I felt, thats Turbo and Standalone ECU fitted and running, just goes to show what can be achieved in little amounts of time
And now to rest,recuperate...... and fit the LC1 Wideband to mine and turn the boost back up :twisted: Marks is faster :lol:
e30_Turbo
Boost Junkie
Post Tue Aug 30, 2005 11:04 am
One of the many pics, more to come later :D
glenn
Post Tue Aug 30, 2005 1:14 pm
did you purposely get a dump valve, with a trumpet!!
it looks a nice install mark.
i bet the drive home from ant's was 'interesting'
i bet your still wearing a grin :lol:
welldone you and ant.
lentec
Boost Junkie
Post Wed Aug 31, 2005 8:21 am
good work guys :D looks :cool:
mark hows it running?
have just got mine fired up with new rockers and shafts on the exhaust side!
not quite feeling brave enough to go for a drive yet tho
with any luck i wont have to change the intake side but i got a full set just incase :wink:
deano325t
Post Wed Aug 31, 2005 8:22 am
looking good ,
you need a hole in the bonnet for the BOV to stick out, :)
this post is an excuse to update my sig :wink:
e30_Turbo
Boost Junkie
Post Wed Aug 31, 2005 12:18 pm
glenn wrote:did you purposely get a dump valve, with a trumpet!!
The dump valve was reccomended to me by a friend on e30tech, seems they like them big over there, not as loud as you would think tho, well maybe it will get louder with more boost, time will tell.
Drive home from Ant's was cool, was too hot for any fun, enjoy the lack of gear changes and the looks as it dumped, but with my exhaust blowing like a pig I bet they were more wondering why I was smiling so much even tho it sounded aweful :D
Managed the 90+ mile trip home in about an hour and half, stopped a few time to check wires weren't melted and and no leaks etc, all good apart from the air filter kept jumping off.
Tonight I fit a DEFI boost gauge and controller and a adjustable boost valve too, so should let me set the boost at 6psi and see what I'm getting. Been running blind till now.
More info/pics to come.
Mark.
e30_Turbo
Boost Junkie
Post Wed Aug 31, 2005 12:23 pm
deano325t wrote:looking good ,
We discussed this actually, but would no doubt get robbed by some chav to stick on his saxo :lol:
Will be getting a vent for the turbo at the weekend, getting the grinder out again should be fun :D
I will post those yellows today, keep leaving them at home as the misses has tidied up and I can't find anything anymore :cry:
Ant
Retired Team Member
Retired Team Member
Post Wed Aug 31, 2005 7:56 pm
Len PM me your addy dude, I'll shoot you those 02 sensors ASAP.
all together now, Whosssssssssssssssh !
325iconv
Post Wed Aug 31, 2005 9:55 pm
looking good mark,nice to see it all came together in the end,would be nice to see the car if your up Halifax way again
lentec
Boost Junkie
Post Fri Sep 02, 2005 6:59 am
Another update!
I have changed the rockers/shafts on the exhaust side! did it on the car!!
Sounds a lot better now! only the usual m20 tickin.
alltho its feeling a bit limp under 4k rpm but when it gets there it roars then screams to 6.5k 8)
Have also removed crap from charger bores and rebuilt it so im going to have a go at refitting that this evening!
if all goes well might even make it to lakeside this weekend!
I think there might be a problem with where ive mounted the expantion tank!
Just cant get rid of the air locks! prob due to it being lower than the top hose
so made up a bleeder to fit in the hose see how that works this eve!
Ant
Retired Team Member
Retired Team Member
Post Fri Sep 02, 2005 7:46 am
be good to see you @ lakeside if you can make it dude
I'll make sure and bring the spare 02s just in case :cool:
e30_Turbo
Boost Junkie
Post Fri Sep 02, 2005 8:47 am
Just a quickie....
After quite a few painless miles, I decided to wind the boost a little, now running 0.3bar, was at 0.2bar, took her out last night in the cold and attached the G-tech, set weight @ 2750lbs (1250kgs) and set off.
After 10 mins of "thinking about it" I opened 3rd totally and was totally blown away, G-tech said max 260bhp, it was cold so I guess a few extra for that, but I'm over the moon, even tho my dump valves was leaking under boost, will tighten that tonight and see if it stops that.
More news as it happens :D
Mark.
Jon_Bmw
Post Fri Sep 02, 2005 1:26 pm
Sounds well :cool: Mark, and thats only at just over 4 psi i think. It puts such a smile on your face i bet. just wait till you're on 7-8psi, but i suspect that it won't be proportionally double the power gain because of heat gains, flow paths e.t.c.
Just spent an hour changing the injectors back to 535 ones and tigtened the AFM 3 clicks/notches then went out for a drive. I tell you you can spin an automatic just by flooring it, but then its not a normal automatic! My poor goodyear eagle F1's. Well one of them. :D
It's fine all through first and second until the red line, no pinking, but under serious load like 100 mph in forth up a hill on a private testtrack, (steep testtrack too :mad: ) it gives the slightest pink. So next is to use bp ultimate or the like, see if that cures it. Or i could stop being lazy and get an intercooler.
Toby_Unna
Boost Junkie
Post Fri Sep 02, 2005 1:54 pm
this is a common e30m30 problem too
if possible unbolt and lift the expansion tank up as high as you can against its hose, hold it with one hand, open bleed screw and rev the motor a little with the other.
the tank only needs to be high up while you're bleeding it. :cool:
lentec
Boost Junkie
Post Fri Sep 02, 2005 2:26 pm
Nice one :cool:
Will give that a go when i get home!
lentec
Boost Junkie
Post Sun Sep 04, 2005 9:34 pm
After an almost succesfull test drive last night (apart from a little :oops: with the charging) thanks again for the jump!
We had a bit of a play on the way home and found that raising fuel an extra 10% at my curent boost level 5psi made a hell of a differance :D So i raised it another 5% today :woohoo: no more knocking!!
Ant you was spot on about those injectors! they running 85% @ WOT/5psi any more boost will need bigger ones!
replaced the alternator (again!) voltage is now 14.2ish so think thats sorted
Just got a massive exhaust blow to sort now!
Ant
Retired Team Member
Retired Team Member
Post Sun Sep 04, 2005 9:48 pm
FI cars do like a LOT of fuel on boost dude :lol: keep your eyes open for that MG V8 in the scrappers :twisted:
85% is OK but as you say more boost and they'll easily go over the ton with some accel enrich thrown in the mix too
Nice to see you and the ride in the flesh Len( and mate, name forgot sorry ), mucho respect from all that turned out for sure.
Turbo-Brown
Boost Junkie
Post Sun Sep 04, 2005 9:50 pm
Had a trial fit of the exhaust this weekend. It's not terrible, but on pretty much any droop of the suspension, the exhaust takes a whack from the trailing arm so that needs sorting.
Other than that, making reasonable progress with the TBs.
Think I need to just work on one thing at a time from now on instead of having bitsa days where I do one thing and then another.
Also discovered that the inlet manifold mounting holes aren't quite big enough to take a normal M8 fixing so I've spent some time today tapping them out to the proper size. Most bizarre!
Also got another thing to add to the list before the car's done: Was told I should not drive unless I'm wearing glasses as my eyesight's not up to scratch :(
Also gotta have a CT scan to make sure I don't have a brain tumor but that's another story.
