Beemerlad's M52 Chromie
Daf318is
Fri Feb 13, 2009 8:21 am
Bob_S wrote:we'll take the golf kid! air conditioned, heated seat luxury!!
and will be over in minutes :)
Oil burner alert!!!! :eek: :eek: The sad thing is i'm actually quite envious!
If we got there for 10 in the morning I reckon it would be finished by mid afternoon if there was enough people....?
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
E30Gheko
Fri Feb 13, 2009 9:05 am
OK possible dates anyone?
Daf318is
Fri Feb 13, 2009 9:09 am
Any weekend excluding this one is fine with me! :cool:
Bob_S
Fri Feb 13, 2009 6:41 pm
fast oil burner I need to work on my 2.8 at some point again it's received a pounding today.
Daf's we'll get up early and get over there. If I'm going everything will be done in a matter of minutes.. dont we know this Dafs? :D
Bollocks to this 24v scrap!
Daf318is
Fri Feb 13, 2009 6:47 pm
Just watch out with Bob though - you go to help him get his engine running and find out he's pulled the rear supension off 8O !
Well I'm up for it - beats laying floor boards anyway! :mad:
Are you up for this Lee?
Fri Feb 13, 2009 6:52 pm
hell yeah, really really grateful for the offers of help from everyone, especially you & Bob, given the distance you are, you're maaaaaad! :)
Just putting a list together of the jobs and will post that up in a few mins
Bob_S
Fri Feb 13, 2009 7:09 pm
mad doesn't come into it lol! been working on my driving technique today... and cooking brake pads :)
Dafs, it's an e30, there is ALWAYS something else broken :( It handled really well today incidentally those arms seemed good and I met the bloke to made them
Fri Feb 13, 2009 7:10 pm
Right, this is vaguely the list of doom (won't be complete as I will have forgotten stuff)
1- Finish fitting drive shafts & tighen flange nuts & large collar nuts
2- Re-fit ARB drop links after I bodged it with bolts which are far too long
3- General check of tightness of any nuts I have had undone
4- Fit replacement brake fluid reservoir, fill & bleed full system (rear calipers could need a rebuild/free off)
5- Fit new rear top mounts (not essential as will be getting some new rear shocks soon)
6- fit gearbox mount
7- fit prop
8- get engine sat on mounts properly as driver side is out and not sitting on subframe properly after pishing about trying to fit S50 manifold
9- fit nuts & bolts to modified steering column UJ
10 - fit clutch master cylinder & plumb in new flexi pipe etc
11- fit gearlever mechanism
12- re-attach handbrake cables and fix/find handbrake light switch
13- check issue with brake pushrod mechanism as feels like it gets stiff and then lets go (maybe something to do with the clio servo or my ham fisted adjustment of bar
14 - re-fit interior
15 - fit ECU under dash (but hole in bulkhead isn't big enough to fit ECU plug through)
16- try to find a way of mating 325 2 piece system to S50 cross-over pipe (welding needed)
17 - I may throw caution to the wind and get a new fuel tank
18- general check over car in anticipation of getting an MOT in due course (after VIC check)
19- Fill cooling system and check for leaks
20- Fit E34 throttle cable
21- laugh at the rust & general tramp theme
Just helping to break the back of that lot and even get 50% done would be a massive step forwards.
This missus will feed us like utter pigs and says we are all utterly sad deluded individuals
**BANNED**
Fri Feb 13, 2009 7:26 pm
13 on your list sounds familiar! Remove servo and brake master,the servo pushrod will require careful alignment with the brake master with a suitable spacer inserted.I have a 16mm spacer at the moment,but it is not quite long enough. Dan did say 18mm afterall!
Youth is wasted on the young.
Bob_S
Fri Feb 13, 2009 7:28 pm
E30BeemerLad wrote:Right, this is vaguely the list of doom (won't be complete as I will have forgotten stuff)
oh dear we have a way to go don't we...
they'll be fine!
why? if it falls off it goes faster?
oh dear I'll bring some calipers up then.
20 minutes!!
easy peasy lemon squeezy...
7- fit prop
sigh..
we'll make mince meat of that!
buzz gun?
30 mins to put slave on, 5 mintes to plumb it!
bish, bosh, bash.
wtf? shouldnt this come before prop?
it'll be fine on the road it's called character
it's only 3 bolts.. dont want some houndstooth sports do you?? :)
oh it is :)
I can "weld"
what? it's already an epic!! lol
is there anything you havn't touched?
I bet the hoses for the heater leak :cry:
oh dear..
If we compare it to mine I won't be laughing :(
Fri Feb 13, 2009 7:37 pm
Parts I need to buy
i) Exhaust hanging system
ii) clutch slave cylinder
iii) radiator top hose (not sure what to buy for the m42 rad)
iv) fuel tank (possible)
v) clutch flexi pipe - wanted ad up already
There must be more than that..
Forgot for the list above, also need to:
22- fit front bilsteins
23- fit drilled front discs + pads
24- check/ free off front calipers
25- locate/ anchor PAS reservoir + fill & bleed system
Theo
Fri Feb 13, 2009 7:42 pm
Lay off the biftas and you will find yourself being much more productive! :P
Fri Feb 13, 2009 7:52 pm
la la, can't hear you :cool:
Daf318is
Fri Feb 13, 2009 7:56 pm
Half an hours work there winkeye
I reckon that lot could be done in a day easily if theres a few of us working on it :D when is it going to happen then?
Bob_S
Fri Feb 13, 2009 8:00 pm
I dunno, we need lee to set a date but I reakon he would chose the 29th of feb.. so we'll go for the 28th :) winner.
might be an all nighter dafs!
I would say in the next 2-3 weeks depending on people's availability and weather etc. I'll get my arse in gear and get the parts ordered. I may even get a few things done in the meantime.
How are interested volunteers fixed?
Omi
Witty custom rank.
Fri Feb 13, 2009 8:04 pm
See you then. :wink:
...or is it?
Fri Feb 13, 2009 8:05 pm
I have a crappy gazebo, will sort a halogen light just incase.
I have a compressor and windy guns & air ratchet, 1 pair of halfrauds axle stands(which don't go that high) and a crap halfords 2 tonne trolley jack, which is like one of the mini ones so doesn't go that high either. Engine crane too. No real workbench though (about 3ft of worktop on a workmate) garage is a shit hole and there isn't a massive amount of room either side of the car.
I don't have a welder, but can hire one for a weekend.
Daf318is
Fri Feb 13, 2009 8:09 pm
Weekends are free for me, I'm a boring person - Monday till Friday 8:30-5!
Just give me a date and i'll be there in my scruffs!
Daf318is
Fri Feb 13, 2009 8:12 pm
I'll bring my welder - i'm pretty good at bird sh1t winkeye !! Made my fannymould though! Even if I did set myself on fire :o: ! I'll bring axle stands too!
Fri Feb 13, 2009 8:27 pm
OK, provisionally Saturday 28th Feb.
Will double check with the boss later when she comes home, just to make sure we're not supposed to be somewhere etc.
Thanks guys, means a lot
E30Gheko
Fri Feb 13, 2009 9:22 pm
Ah that rules me out then. Not that I would have been much help anyway. :o: Best of luck with it tho fellas. Sounds like there will be a lot of progress on the 28th. :thumb:
Gortour
Fri Feb 13, 2009 9:35 pm
See what Mod status does Lee? They're all trying to 'suck up'... winkeye
Seriously, only kidding guys, wonderful to see the offers of help. Makes me proud to be a member of the Zone.
:group: :thumb:
Bob_S
Fri Feb 13, 2009 11:03 pm
I'll bring my big jack if I fix it.. was going to offer my welder but dafs is bringing his..
get everything we need, we dont stop until we starve or finish
Lee, is it a NV lump? fancy a pair of nice shiney cams?
Sat Feb 14, 2009 12:26 am
Yep, it's non-vanos. I'd like your cams very much but ain't got the dollars at the mo :(
Daf318is
Sat Feb 14, 2009 8:26 am
E30Gheko wrote: Sounds like there will be a lot of progress on the 28th. :thumb:
Correct
It's going to be finished on the 28th :D
Sat Feb 14, 2009 10:31 am
Right, confirmation from the mother ship, 28th is a GO!
You heros :cool:
Gortour
Sat Feb 14, 2009 11:59 am
Well done and thanks guys. This is really nice to see. The Zone spirit is working well. :thumb:
Daf318is
Sat Feb 14, 2009 3:12 pm
Two weeks today! How many of us are there going to be in total?
Daf318is
Bob_S
Sat Feb 14, 2009 3:18 pm
Daf318is
Bob_S
Omi
Can you & bob PM me your mobile numbers, I did have bob's on my other mobile but lost it. Got Omi's already.
Will sort out directions etc nearer the time
Thanks again guys, stellar effort
buster
Sat Feb 14, 2009 6:18 pm
id love to help mate.I need to check with the missus.
Omi , can i cadge a lift ?
Sat Feb 14, 2009 8:31 pm
Nice one Andy, let us know.
How can you have a missus with all the vehicles you have? :D
Bob_S
Sun Feb 15, 2009 9:58 am
omg, what a day i'm fubar bloody e39's!
sounds good!
Gortour
Sun Feb 15, 2009 10:56 am
Bob_S wrote:omg, what a day i'm fubar
That cos of a car, or Valentines? :snigger:
**BANNED**
Sun Feb 15, 2009 4:20 pm
Image Lee,you mention PAS location,I fitted mine,as you can see here,behind the n/s headlights. That's the one off the E34,because the bracket was a more suitable shape.Thinking about it( dangerous),the container(I cannot spell reservior)is only mounted on the n/s to suit the original LHD instalation..the pipes run under the sump alongside the rack on RHD.If I were to do this again I would look at fitting the PAS thingy on the o/s inner wing,behind the washer bottle and above the exhaust.I reckon it would be quite easy to get suitable pipes made up to suit this.Other point is how are you switching your electric fan? I used the E34 radiator(non air con) and have made up a fitting from a bit of surplus exhaust pipe and a nut to fit my switch into the top hose.Top hose is 42mm internal diameter BTW,I found that the E34 one did not fit comfortably,went to a friendly motor factor mid-afternoon when they were not busy and got the guy to search his stock for a pipe of the correct ID with a sharp right angle bend,sliced this to fit either side of the thermo switch.Thermo switch was from GSF,ask them for an air con fan switch! E34 rad. is about half an inch taller than standard M20,I needed to weld a pair of 'ears' to the slam panel to extend the top mounting bracket holes.Lower rad mounting is two small plastic feet,E30 uses one small one and one large one,so does E34,so I had to mix and match from both instalations.Hope this helps when you are sorcing bits for your 'zone meet',not too sure if I have time to make the big day!
