Beemerlad's M52 Chromie
Post Tue Sep 15, 2009 5:10 pm
I'm sure there was an excuses thread already started..
Make sure your rad is properly attached and you'll be fine
djk
Post Tue Sep 15, 2009 5:36 pm
Looking very very promising! Can't be many regular zoners not following this thread, surely one of them could bake a touring shaped cake or something :D
Post Tue Sep 15, 2009 5:58 pm
Cable ties FTW, even mine has extra strengthening via cable ties :)
gareth
Post Tue Sep 15, 2009 8:05 pm
blowing it up on the strip, that'll never happen winkeye :P
cable ties on the rad are awesome, they've held the bottom of my rad on for the last threee years or so :)
Post Tue Sep 15, 2009 10:28 pm
:rofl:
Cable ties saved my bacon.. Got me to work for a couple of weeks after also :D
Post Wed Sep 16, 2009 10:53 pm
Got the day off work tomorrow, just printed off my insurance certificate, ready for my first proper ride out in the car since getting it 2 years ago! VIC check at 1.40pm, hopefully have some rent in the screen later in the afternoon
Post Wed Sep 16, 2009 10:57 pm
*Fingers crossed* :D
johnl320
Post Wed Sep 16, 2009 11:00 pm
Excuse me for being thick, why does it need a VIC check and whats involved?
Post Wed Sep 16, 2009 11:01 pm
It was a CAT C
It just checks that it is numbers matching basically
johnl320
Post Wed Sep 16, 2009 11:04 pm
Ah, didn't realise it had been written off. Cheers Jhonno
Good luck :D
Gortour
Post Wed Sep 16, 2009 11:05 pm
Best of luck Lee.
**BANNED**
Post Thu Sep 17, 2009 2:03 am
Vehicle Identity Check.
In Lee's case his car was a cat 'C' insurance write off,check is to make sure the car has not been 'rung'.
My touring also required a ViC,but because it was an import from France,on French plates.
All the guy was interested in was the VIN number and engine number so that a V5 could be issued,with an 'age related' regestration mark.I turned down the latter and used a retained mark!
Youth is wasted on the young.
blitz877
AKA ajm-e30
Post Thu Sep 17, 2009 1:53 pm
good luck withthe check mate :D
d6dph
Post Thu Sep 17, 2009 1:56 pm
Good luck Lee. I really want to see this at pod.
Dezzy
CR24v it's a lifestyle
Post Thu Sep 17, 2009 3:49 pm
Any news lee?
dazleeds
old skool raver
old skool raver
Post Thu Sep 17, 2009 4:19 pm
he should be waiting in line fr a tax disc now i reckon
www.oldskoolfantasy.co.uk
d6dph
Post Thu Sep 17, 2009 4:23 pm
Or ringing the insurance company " I don't know what happened, I was just pootling along on my way to church and it caught fire, What... Yes my church is down a quiet country lane well away from any witnesses"
Post Thu Sep 17, 2009 4:49 pm
He has a tax disc :)
Yep indeed, VIC check passed and it has some rent in the screen.
Few problems though. Horrible clunking from the front end over speed humps and potholes etc. Just discovered after taking the driver front wheel off and looking around that the collar nut on the strut has come undone completely and the insert is just flapping about. So am in the process of removing the strut etc.
However, of more concern is a diff that is absolutely howling for mercy. Or at least that's what I believe the noise is. Going to investigate that once I've rebuilt this strut. Have booked tomorrow off work now, so there remains a chance this will come to the pod.
Ziggy
Post Thu Sep 17, 2009 4:53 pm
Good work sir! Got a spare diff?
beemerbird
Post Thu Sep 17, 2009 4:54 pm
Woo hoo (ish)
Sounds like all your perseverence is finally starting to pay off.
Dezzy
Post Thu Sep 17, 2009 4:57 pm
Stick the LSD in lee job done! Well done mate. What's it like then. Are you happy with it sir? winkeye
Post Thu Sep 17, 2009 4:58 pm
Ziggy wrote:Good work sir! Got a spare diff?
As it happens I have a 3.91 LSD waiting to be fitted :) Remind me, is it 17mm bolts that hold the diff in?
Dezzy
Post Thu Sep 17, 2009 5:00 pm
4 17 mm bolts and 8mm allen bolts on the drive shafts mate
Post Thu Sep 17, 2009 5:03 pm
Dezzy wrote:Stick the LSD in lee job done! Well done mate. What's it like then. Are you happy with it sir? winkeye
Aye, LSD will be going in.
I'm still on the fence with whether I like it or not. The horrendous howl coming from the back end/ underneath kind of ruined the journey. But it rides very well. Seems quite sluggish bottom end wise (presumably a price you pay for the M50 inlet manifold and probably the S5 exhaust manifold). The exhaust manifold may be too loud for my liking.
I think once it has had a bit more of a shakedown, I'll look at getting it remapped and see what that brings, but it doesn't feel like a missile
Dezzy
Post Thu Sep 17, 2009 5:10 pm
It should do mate Shouldnt it. Could it be wheel bearing mate?
Jon_Bmw
Dangerous when thinking
Post Thu Sep 17, 2009 5:13 pm
Well done. I thought this day may never come! :P
Get out there now and get the diff swapped. Have you checked there is oil in the one that is on the car?
Post Thu Sep 17, 2009 5:18 pm
The diff in the car may be low or empty on oil as it did get stored on the side by mistake and a load did leak out of the breather. I have no idea what ratio it is, but it was doing 3k at 70mph
Shouldn't be a wheel bearing as all 4 are brand new.
Just found the windy gun and spring compressors so will get this strut finished and then have a look at the rear end. May run it in gear with the arse in the air to see if it isn't anything else
Ziggy
Post Thu Sep 17, 2009 5:35 pm
I'd just lob the LSD in & see if that fixes it - you're clearly going to want to do that anyway so why waste time on anything else?
GeoffBob
Forced Induction Specialist
Post Thu Sep 17, 2009 5:58 pm
Congrats on the VIC Lee. Hope all comes right with the diff.
**BANNED**
Post Thu Sep 17, 2009 6:06 pm
Sounds like current diff is a 3.64 or there abouts,any play in the prop centre bearing?
Dezzy
Post Thu Sep 17, 2009 6:11 pm
If it's an orig diff out of the 318 touring won't it be lower than that? Best to run it on the jack like you said mate.
leeparkes
Post Thu Sep 17, 2009 6:14 pm
3.64 gives 75mph @3k, id guess its a 3.91.
Anyway ive been following this thread from day one and im glad to see its (almost) complete.
well done lee and enjoy!
Post Thu Sep 17, 2009 6:32 pm
I agree with Lee, 3.91
Post Thu Sep 17, 2009 8:49 pm
I ran it with the arse in the air and there is all sorts of clunking and grating noises coming from the diff, so I'll have that out in the morning and wrestle the LSD in. Will check the other drivetrain components for wear too
Dezzy
Post Thu Sep 17, 2009 9:16 pm
That's good mate. You think you have sorted the clunk as well?
