My S50 conversion.Done !
gooner1
Out humping Reindeer
Post Mon Sep 11, 2006 5:23 pm
here you go Dan
Post Mon Sep 11, 2006 5:57 pm
You know I saw those the other day and just compared them to busters, it looked to me like the mounting plate was on back to front.
Was it the firm in the West Midlands?
If so its on the doorstep :D
Cheers for those pics 8)
Post Mon Sep 11, 2006 5:58 pm
Hope mine ends up looking 1/2 as good!! :cool:
buster
Post Mon Sep 11, 2006 6:30 pm
cheers Jhonno ,im sure it'll awesome when its done.
That brace above looks a bit different to mine i think.The end plates look thinner and the cut outs look bigger.
tbmw
Post Mon Sep 11, 2006 7:35 pm
damn good lookin project
as said looks factory finished
has inspired me to get my arse in gear and try to do one myself
A clear conscience is a sign of a bad memory
bmw13fr
Post Mon Sep 25, 2006 12:13 pm
hi,
have you cut the plenum to put the servo ?
thxxx :)
jmc330i
Post Mon Sep 25, 2006 12:21 pm
bmw13fr wrote: have you cut the plenum to put the servo ?
Im pretty sure he did. Its the only way the servo and plenum will fit together in the engine bay. Its how I did mine.
James
'91 325i Sport
'93 318i touring 16v
buster
Post Mon Sep 25, 2006 3:28 pm
bmw13fr wrote:hi,
thxxx :)
hi,yes i had to cut a small amount out.About 2 inches long ,by 1 inch wide.I also fitted a vw golf servo which is smaller,and i still had to move the whole lot over on the bulkhead by half an inch.I suppose i could have cut more out of the plenum chamber but i was minimising the amount needed to be cut out.
cheers
andy
bmw13fr
Post Mon Sep 25, 2006 5:42 pm
ok, thank you :D
I saw a swap where the guy did not cut out the plenum chamber
he moved the servo in front of the car
Frenchguy
Post Sat Sep 30, 2006 9:05 pm
bmw13fr wrote:ok, thank you :D
Yep, il a utilisé un mastervac + support et commande de 540i E34. J'en ai à vendre si tu veux.
For you Brits : there is still the E34 V8 servo assembly solution. But then there's not that much space available up front .
eko
Old timer
Post Sat Sep 30, 2006 9:16 pm
Buster that is awesome!
Attention to detail has really paid off,looks fantastic :cool:
Credit to you mate :)
buster
Post Mon Oct 02, 2006 1:34 pm
cheers Eko :thumb:
Ive seen your having fun with an m50 conversion ! its all good fun !
jaistanley
Post Wed Oct 04, 2006 1:35 pm
Does the E34 V8 have a remote servo then? (couldn't see one in the picture on real oem)
If I can use a radiator with a built in header tank I could fit one in I'm sure. Might even be able to do away with the pull bar brake pedal in that case.
Jai
buster
Post Wed Oct 04, 2006 7:09 pm
i think the v8 one is on a long shaft like mk 2 escorts i think e21's were like this also.Servo sits near back of headlight.
I still think it will foul up every where.There would be no room for the air filter neither.
e30-323ti
Post Wed Oct 04, 2006 8:51 pm
Hi Andy,
Conversion looks great.
1 Question, how did you do those bonnet vents??
My engine bay gets a bit toasty with a couple of turbos crammed in there!!
ste
Post Thu Oct 05, 2006 11:25 am
Looks good Buster. :cool:
buster
Post Fri Oct 06, 2006 3:34 pm
e30-323ti wrote:Hi Andy,
They were just cut out of a stainless steel machine panel and ,the bonnet cut and then vents welded into place.The one on the exhaust side kicks out a lot of heat,the one on the other side is a bit of a pain in the arse and i had to cover the back of it with a piece af aluminuim plate to stop rain water getting on the air filter.
Ste.
Cheers fella,im keeping an eye on your conversion it looks spot on,it'll be a really nice conversion when its finished.
I was thinking of making an oil fitting that you have got to convert the oil cooler lines to AN10 fittings.I still have my oil cooler to sort out as it is just fastened onto the bottom of the rad at the moment.
Also need some tasty wheels,the alpina reps (not bk's though) have got to go !
cheers
andy
tonyeyles
Post Fri Oct 13, 2006 1:31 pm
Is this conversion up and running now?
buster
Post Fri Oct 13, 2006 6:53 pm
yes
e30s50b32
Post Tue Oct 17, 2006 1:05 pm
Excellent work!!
I am currently putting a S50B32 with a euro six speed in a US E30 M3 and need some help. I was wondering if you guys help me out?
1. I don't have the complete EWS system. I am missing the key, the antenna box and another EWS box. Can I bypass the EWS system? Can I use a any US e36 key/antenna box/two EWS boxes (all from same doner) with the euro ECU? Does anyone know a good junk yard in UK?
2. Is the iX brake booster and e34 m5 25mm mc better than 320 booster and e30 m3 mc if I was to use big brakes? Would all these require to cut the intake manifold?
3. Anyone dyno the differance between a single 3" exhaust vs dual 2"? What muffler did you guys use?
4. Did you guys use the Treehouse ECU plug? Is there another?
5. How did you get away from notching the subframe and bending the sway bar? What motor mounts did you guys use to allow the exhaust manifold to clear? I know some of you used costum manifolds but I like to keep the stock manifold in that I hear itâ┚¬Ã¢”ž¢s the best flowing.?
Thanks for the help
Art
jmc330i
Post Tue Oct 17, 2006 6:52 pm
e30s50b32 wrote:Excellent work!!
Thanks for the help
Art
I have replied to your PM :thumb:
James
'91 325i Sport
ian332isport
Post Tue Oct 17, 2006 7:57 pm
Thanks for the help
Art
So did I. Have you checked your email ?
buster
Post Wed Oct 18, 2006 8:19 am
great,saved me a job :cool:
MR_SAZ
Post Thu Jan 11, 2007 1:38 pm
what a awesome thread! u must be loving the S50 E30! hows the 3.64 diff now??? better??
buster
Post Thu Jan 11, 2007 4:11 pm
still on the 3.91 LSD at the mo 8O
MR_SAZ
Post Fri Feb 02, 2007 12:46 am
Hey all ive posted this up somewhere i just cant remember on which forum now...
AZEVEDOMotorsports use a suzuki swift servo and mc, it clears everything, he has pics on his conversion page,looks very interesting to say the least!
have a look below!
http://www.azevedomotorsports.com/galle ... mber=1[url][/url]
Also u can use the E32 735 or the 325ix servo
http://www.azevedomotorsports.com/galle ... temId=3138
http://www.azevedomotorsports.com/galle ... alNumber=2
look at the mc it looks like it hits the intake boot to the manifold, i think it just works....i think i like this one!!!! anyone??
sash
Post Fri Feb 02, 2007 9:14 am
Is the Suzuki servo a twin diagphram type like the iX? If it's just a single diaphragm, then it looks a bit short on surface area.
buster
Post Fri Feb 02, 2007 3:00 pm
Apparently the suzuki one isnt up to the task,not enough vacuum.Its a single diaphram servo.
MR_SAZ
Post Fri Feb 02, 2007 4:15 pm
so the best bet would be the E32/IX servo....
i went to buy one today...someone bet me to it though... i have to wait till another one comes along...
buster
Post Sat Apr 07, 2007 8:50 pm
Just thought id add a few pics of todays work.,
I fitted the m3 control arm bushes,and swapped the struts to the m3 ones.
heres the eccentric bush :
Spax shocker,been in there 4 years and still looks good :
Heres a pic of the centre section of my exhaust.2x 2.5" stainless steel pipe :
I didnt take a pic of the 5 stud hub as its the same as the 4 stud but with an extra hole :mad:
Although i will if anyone wants to see.
cheers
andy
glenn
Engine Transplant Services
Post Sat Apr 07, 2007 8:59 pm
good work andy.
carlsberg export :drool: :lol:
buster
Post Sat Apr 07, 2007 9:09 pm
Cheers Glenn,it makes it difficult working in such a tight spot between the house and wall.
Was hot today so needed the export refreshment !!
bigpimpin
Post Sat Apr 07, 2007 9:14 pm
Good stuff andy!
Many stellas/carsbergs were consumed in my garage during the build! winkeye
What springs/shocks you using?
www.m3touring.com
old_skool
Post Sat Apr 07, 2007 11:04 pm
Looking good!
Did you fit the M3 style drop links to the struts? Any difficulties?
Beer is more important than WD40 when it comes to fixing motor cars.
buster
Post Sat Apr 07, 2007 11:11 pm
Suspension is the spax psx kit i bought for the sport about 4 years ago.Kit was 4 springs and dampers so i've just re used them.
I haven't fitted the m3 drop links yet Dameon,i need to do those next.
