My E30 M3 S85 V10 Swap
glenn
Engine Transplant Services
Thu Dec 15, 2011 8:04 pm
i haven't steve :(
i've got a few boxes here from the bodyshop, so i dont know what i've got and what i haven't yet.
what, you need some steve?
oddisE30
Thu Dec 15, 2011 9:03 pm
You got the making of at good chistmas gift there Glenn, not many get E30 M3 V10 for christmas :eek: Even if you had to build and pay for it, not bad!
Remember to take some pics outside before you push it in the garage, mush easier to get the Imola II 'flare' trough the lens :)
glenn
Sun Dec 18, 2011 4:30 pm
i finally got the car home on friday evening, and had a good look over it on saturday. i'm very happy with it. the pictures i've taken though dont seem to show the colour as dark as it is, i'll have to see if i can turn the flash off.
anyway, i had a play with it today.
i need to be able to get the car in and out of the garage to work on it, but the engine is in the way, so the best place for that was back in the bay!
i'd forgotten how tight it was going back in
also put the rear quater windows back in, which took longet than expected, with a lot of swearing at the rubbers, also put the sunroof rear drains back in.
fuzzy
He who sleeps with "Gingers"
Sun Dec 18, 2011 4:32 pm
you do this from home? 8O the engine didnt look like it would physically fit in the engine bay.
:eek: That's tight!
glenn
Sun Dec 18, 2011 4:41 pm
fuzzy wrote:you do this from home? 8O
hell yeh! 8) :lol:
turk
Sun Dec 18, 2011 5:03 pm
At last!!! U'll have it running by new years day mate :D
I might be in brynmawr just after xmas day so might have to 'pop' by.
Well done bud, looks mega impressive. What news on the ecu?
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
BMWE30325
Sun Dec 18, 2011 5:44 pm
love it :D keep it up mate you are an inspiration to many.
MIKAM3
Sun Dec 18, 2011 8:36 pm
Very good job Glenn , wait about the rest :)
Sun Dec 18, 2011 11:38 pm
Fack me Glenn that donk is tight !!
next time lube the window rubber with wd40 they will slide right in !
fitting the cog box in this will be epic !
Cook318IS
Sun Dec 18, 2011 11:39 pm
Yay progress :D Looking forward to see you cracking on with it!
turk
Thu Dec 22, 2011 10:39 pm
C'mon Glenn I need something to read over xmas... :D
Sump Baffles
TrackDays
MIKAM3
Wed Dec 28, 2011 2:16 pm
What model do you use ?
Uploaded with ImageShack.us
senna
Wed Dec 28, 2011 3:20 pm
glenn wrote:almost finished the new crossmember, here's a couple of pics......
Hi Glen, excellent work:
Will the fact that the steering rack has moved forwards induce a form of Bump Steer?
glenn
Wed Dec 28, 2011 5:45 pm
MIKAM3 wrote:What model do you use ?
that prop is off an e60 m5. i bought it as i needed the first few inches for my own prop. i may use the u/j's off it too. i got it for a good price.
senna wrote:Hi Glen, excellent work:
thanks.
i'll be making a small alteration to that crossmember, to move the rack closer to its original position, to deal with bump steer. i dont think it will be affected though, not until you've almost got full lock on.
MIKAM3
Wed Dec 28, 2011 8:00 pm
Thank's Glenn :) , I think that I will use the M3 E36 steering !
turk
Mon Jan 02, 2012 10:04 pm
any progress bud?
Sump Baffles
TrackDays
glenn
Mon Jan 02, 2012 10:43 pm
turk wrote:any progress bud?
not on the conversion side of things, adem,
i've been bolting things back onto the car after getting it back from the bodyshop.........
sunroof & mechanism
head-lining
boot trim
rear axle
door trims.
almost finished those things today, and i've started to look at what i'm going to do about brake activation. i think i'm probably going to mount a servo behind the dash. going to have a deeper look at it this week.
winx
Mon Jan 02, 2012 10:58 pm
turk
Mon Jan 02, 2012 11:08 pm
Why not use a pedal box?
Sump Baffles
TrackDays
glenn
Mon Jan 02, 2012 11:12 pm
yeh, i've looked at remote servo's henry, and i've thought about pedal box's adem, but i quite fancy having a play with mounting a servo behind the dash to be honest.
:mad: ......i know!
turk
Tue Jan 03, 2012 1:40 pm
glutton for punishment :D
Sump Baffles
TrackDays
e30-EVN
Sat Jan 07, 2012 3:20 pm
She looks the business glen! Your work here will inspire many I'm sure, absolutly brilliant mate.
:cool: :twisted:
ShepsEvo3
Master of go faster
Sun Jan 08, 2012 12:09 am
Glenn...
Awesome.. well, she's red now winkeye
Would love to pop over and have a look... been a journey so far for you :roll:
www.sabre-tuning.co.uk
glenn
Sun Jan 08, 2012 9:08 am
ShepsEvo3 wrote:Glenn..
your welcome anytime paul. :D
glenn
Sun Jan 08, 2012 6:01 pm
after looking in more depth at the brake activation, i decided not to mount a servo inside/behind the dashboard. its possible to do it, but there just isn't enough room to hide it completly.
so i've decided to mount the sevo/master cylinder in header tank area, as i'll be using the M5 header tank.
i've used a clio servo, and will use a m/cyl off a 750i.
i'm basicly using some of the parts off a rhd e30, mainly the rod that goes across the inside of the bulkhead, behind the heater box. the part i've fitted on the 'battery tray' is a 'modified' pivot bracket from behind the rhd glovebox. i haven't done the pedal box yet, i'll get pics of that once its done.
if you look close at this next pic, you can see the hole i've made to allow the activation rod to come through the bulkhead, and i've used a rear axle abs 'grommet' to neaten up the hole
rear axle fitted........
also re-dyed the parcel shelve's black......
turk
Sun Jan 08, 2012 6:18 pm
Nice! Are you able to just flip the rhd pivot bracket upside down to re us?
Sump Baffles
TrackDays
glenn
Sun Jan 08, 2012 6:24 pm
turk wrote:Nice! Are you able to just flip the rhd pivot bracket upside down to re us?
um...yes,i suppose so,
its mounted here, the same way as its mounted in the rhd car.
turk
Sun Jan 08, 2012 6:43 pm
doesn't that put the push arm on the wrong side ?
Sump Baffles
TrackDays
glenn
Sun Jan 08, 2012 6:58 pm
wrong side??
each leg of the 'L' pivot piece, is at different levels,
so the rod from the pedal, can cross the servo push rod without interference.
i'll get a pic up of it once i've done it.
glenn
Sun Jan 15, 2012 6:57 pm
i've almost finished the 'in car' part of the brake activation today.
just need to clean up some welds, and tidy up some of the cut-out's etc, but here's a few pics of how i've gone about it. it's mostly made up using the parts off a rhd car. i'll also have to relocate the heater pipes slightly.
i probably would of put the servo/m cyl down behind the nearside headlight area, but i wanted the original airboxes, and one of them will be in that area.
i thought i'd try and get some of the car, without the flash, although it does have a fair bit of dust on it now........
and one with the 25mm 750i master cylinder
turk
Sun Jan 15, 2012 7:31 pm
Nice work mate!
Sump Baffles
TrackDays
sean_318i
Mon Jan 16, 2012 7:24 pm
Liking how this is coming along.
I think it would be worth blanking up the master cylinder and bleeding it to test though.
I would be interested to see how much the brake pullrod flexes now that its been turned into a pushrod. This is something I always look at when designing a linkage.
Hope I havent thrown a spanner in the works but it would be a pain to find out after the car is built.
Sean
glenn
Mon Jan 16, 2012 7:43 pm
no probs sean,
i had a good play about with this before i decided to use it. its suprisingly strong. i could get most of my bodyweight on it, and it was still straight.
i would of used it as a 'pull' rod, but there wasn't enough room to put the reverse lever on the clutch side of the pedal box.
i've 'tested' this set-up after i'd fitted it,and i was pleased with its performance, i'm confident it will be fine.
sean_318i
Mon Jan 16, 2012 7:56 pm
