Recently picked up some 16x9 borbet A's that had seen better days and have started to refurb them as you can see from the pics below. the dish will eventually be mirror polished when i get round to buying some good metal polish.
i initially used paint stripper to get rid of the scabby paint and clear coat and then hand sanded/polished the dish using progressivly finer grades of wet and dry.
wheel centres were primered, painted and laquered.
At the time i just used finer and finer grades of wet + dry.
I have since used 00 grade wire wool on them, and that seems to remove any harsh scratches (that won't polish out) and replace them with very fine scratches (which will polish out).
I spent alot of time trialling different polish's aswell to see what gives the best finish, and the one I recommend is Meguiars NXT Metal Polish. It cleans any imperfections out very well, and also gives a superb finish, whilst repelling water aswell (and thus helps when it comes round to cleaning them). There are better products out there, but i use that whenever i clean the wheels (every 2-3 days) as it's easy to use. I apply 2 coats of it, and it keeps the wheel well protected.
I flatted mine down using a sander and P240 and then gradually worked upto P2000. You could try using the wire wool after the P240 to try and remove the harsh scratches and it should make life a little easier.
They should look good on your car with the polished dish.
Breaking 325i Touring
