**316 project...story so far **
aceraf
Post Sat Mar 24, 2007 1:17 pm
My first external mod on my car...I bought a complete spare grill for my car aswell as some eyebrows...
I wanted to black the grill and colour code the eye-brows....
I could've easily done this at home with a spray can and probably would've got a very good finish...but i wanted to do it perfect....so i decided to spray them at college (i could also do a write up on it, and use it for my college work)....
I took my time, and prepped all the panels, red-scotching to give a good key, and applying 3 coats of etch to the chrome kidney grill...i then applied some primer, checked the panels, and most were okay....so proceeded to paint (didn't need flatting, as most parts were coated quite well, and flatting probably wouldn't make much difference as there's not much surface area on show).
I then mixed up some water-based gloss black, and applied 3 coats..(eye-brows will be red, and need flatting so removed them!)
I then mixed up the lacquer, and went back to spray them, and noticed that i had little yellow over-spray from the person who'd been spraying on the other side of the booth!!! :-x
2 hours worth of work...wasted...!!! I then didn't bother lacquering..!!!
I could put the grill on as it is, as you can't really notice the dots untill you look closely, but i want them perfect, as i don't wana have to mess about with them again, so I will be re-spraying all!!!
I also noticed someone touched the kidney grill while i was out of the booth, and you can now see the primer on 1 spot on the grill!!! :-x
Anyway, here's some pics of the story so far.... will post pics of the finished product, and how it looks on the car once i've resprayed it this thursday!!!
Couldn't resist putting them on the car...just to see how it looks....
front bumper needs tidying up, and front wing needs knocking out....might just replace it along with the other side wings aswell as they have a little rust at the bottom mounting screw!
Kidney Grill doesn't line up properly yet, and eye-brows need colour-coding....the eye-brows have been removed (they were only placed on for the pic!)
Finally - before Image After - Image
Still to come:-
60/60 drop
17" RH's :drool:
Mtec 2 Kit
Full respray (not sure whether to keep it Brilliant Red, or change it!)
Tinted Windows
ICE
winkeye
Breaking 325i Touring
Hyperion
Post Mon Mar 26, 2007 9:05 am
Hi mate, i also have the black grill on my car, but i took the easy way, just took the old one off, covered up the vertical strips and sprayed her. to tell you the truth it did start peeling after a while but a quick touch up worked wonders. I am pretty sure yours is going to last. :wink:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Mar 26, 2007 10:29 am
y get rid of the chrome :cry:
aceraf
Post Mon Mar 26, 2007 12:23 pm
cliffybabe wrote:y get rid of the chrome :cry:
LOL....
Unless I was to spend big and chrome the whole car like yours i think it makes the car look dated...
Your cars looks very good, and IMO you've done a very good job in getting the chrome to suit the car....
but that's not what i'm after...
I like a clean look, and the chrome just stands out too much!!!
The only chrome going on my car may be chrome wheels....but they'll have to be deep dish...I want to try and get hold of a set of RH's, and then either polish the lip, or chrome it!
aceraf
Post Mon Mar 26, 2007 12:26 pm
Hyperion wrote:Hi mate, i also have the black grill on my car, but i took the easy way, just took the old one off, covered up the vertical strips and sprayed her. to tell you the truth it did start peeling after a while but a quick touch up worked wonders. I am pretty sure yours is going to last. :wink:
Even still....i'm going to do it again...want it perfect....!!!
It seems strange why i would do it when you lookl at the pics, and see the state of the bumper + wing...but they're things i'm working on fixing...just don't get time!!!
Plus, if i get another e30 (hoping to get a e30 325i cab towards end of year!!!), i can take the parts i've worked on off this one, and put them on the other one!
choppa7
Post Mon Mar 26, 2007 12:40 pm
Looks good mate, I'm trying to find time to spray a spare set of kidney grills I got from a scrappy and I've wondered how they would look, the before and after pics give a spot on idea.
Nice one!
1990 318i Lux
aceraf
Post Mon Mar 26, 2007 1:19 pm
choppa7 wrote:Looks good mate, I'm trying to find time to spray a spare set of kidney grills I got from a scrappy and I've wondered how they would look, the before and after pics give a spot on idea.
Nice one!
I had seen a few posts (and i'm sure i asked the same question a few times aswell) of people asking to see a before and after, so I thought if nothing else it can help other's decide which look they prefer!
I just wish my bumper/wing were more tidy, but just got no time to sort that yet!
I'm sure on a tidier example, it would make more of an impact (or the lack of impact with the chrome gone), but think the gloss black helps the front end as opposed to the grey standard plastic!
aceraf
Post Wed Mar 28, 2007 6:20 pm
Tech2 spoiler (FREE courtesy of a good friend :D ), soon to be prepped and sprayed red!
Will test fit it, and take some shots soon!
aceraf
Post Thu Mar 29, 2007 7:09 pm
You can't see it in the pics, but the spoiler had a few chips on it, and some strange bubbles in the paint....
took it to college to work on it, and guess what i found....
one whole side of the spoiler has been filled with normal body-filler, on a fibre-glass spoiler!!!
WTF didn't the Tw*ts just use fibre-glass filler???? :x
Now i have to cut a big hole in it, and do the job properly....
it also had some really shit paint on it, and lots of it too....
I'll get some pics on shortly, and you'll be able to see what i mean!!! :x
On a positive note, got the eye-brows wet-flatted, and apart from one bit of stopper needed, they're ready for paint!!! :D
aceraf
Post Thu Mar 29, 2007 7:16 pm
You can just about make out the crack in the spoiler in the 4th pic down...!
Image[/img]
aceraf
Post Fri Mar 30, 2007 11:15 pm
here's next thing on the agenda (after finishing the spoiler...gota wait 2 weeks as can't be bothered to mess about with fibre-glass at home...i'll do it at college!)
Got them through this morning....1 decent set of smiley headlights...
gona smoke them as per the zone guide!
I'm also gona clean and polish up the glass lenses...the glass is a bit rough at the moment..so gona get is silky smooth!!!
the lights have a few issue such as broken clips etc...so will have to make 1 good pair out of these and the one's on the car...but should be okay!!! nothing major!!!
I'm actually seeing some progress in this project now...!!!
Still waiting on the MOT results to determine when/if the suspension drop, and more expensive mods will be coming!!! winkeye
Still trying to source the parts i need for as low a price as i can...need to keep costs down if it's gona get everything on my list:-
60/60 drop
17" RH topline's
Mtec 2 Kit
Tinted Windows
ICE
smoked head-lights
Xenon Light conversion
Leather interior (preferably sport + heated)
and if that takes over 2 years then.... new engine!!! winkeye
Quite a list...and i'm sure quite a price tag aswell :cry: ...especially considering the car cost £150 8O ....why do it...not sure why...??? :?
aceraf
Post Sun Apr 01, 2007 4:39 pm
Gave my car a good clean today (took about 4 hours!)
Washed...
Dryed...
Hoovered(sp)...
t-cut...
polished!!!
I buffed the whole car, and did the bonnet about 5 times....
it was white and pink when i started, and is now a healthy red (even though that reds different to the rest of the car!!!) Realised afterwards i should've done the roof and boot a few more times aswell...oh well!!!
The pics aren't great as were taken in the sun, but i assure you the car doesn't look as orange as it does in the pics!!!
Before:-
After:-
ImageImageImageImage ImageImageImage
I'm going to repeat the whole process again when my Farecla G3 arrives (been waiting 1 week, and couldn't bare to see my car that dirty anymore so decided to wash and polish, and then reapeat next week!)
aceraf
Post Wed Apr 04, 2007 11:36 pm
I did actually get the G3 through the very next day, so decided to treat the car, and give it another wash, and then a treatment of G3 all over the car, before another coat of wax polish...
A few more pics...
Quite like this one...
