my bm e30 320i
th3_duckst3r
Post Sun Jan 07, 2007 1:53 pm
Image[/img]
th3_duckst3r
Post Sun Jan 07, 2007 2:39 pm
as u can c the rear spoiler has intergrated brake lights ive never seen this type with it in does have a name on underside ill try get what it says.it is clean with just a couple of surface rust but very small ,could do we a tcut but damn english weather prevents this.inside good no rips tears etc.as again just needs a good clean,everything works as should.i just need to change a few fluids ie power stearing,coolant.oil is dun.only had it 5 weeks and 3 of those ive been on holiday.could someone tell me if these are standard wheels? ohh and im on the hunt for some window winders as one had snapped .still a damn quick car for its age and i do get plenty of looks u dont c many 2 doors in this condition .differential a bit noisey then again could do with fliuid changing anyone in leeds area good we bms give me a pm as could do we a good check over....
mrLEE30
Post Sun Jan 07, 2007 3:01 pm
nice clean lookin car, a good base to start the modification bug!! first thing you need to do is resize your avatar.
the mtech copy rear spoiler is probably from autotint design or similar does not look too bad IMO.
These are certainly not standard wheels but copies of the BBS design. they look like 14 inch, if you are short of cash get some 14inch bottle tops and swap the tyres over, will look 100% better. a set should be easliy picked up for 50-60quid without tyres, then get rid of those mudflaps and bits and pieces stick to your windows!!
note the rust around the rear light clusters, remove the boot carpet and have a good look (a bit appears to be on the boot lid too) remove the lights ( 8 bolts from the inside) and sand away the rust and repaint before it gets too bad (it will not be visible anyway) and chack around the inside of the sunroof for rust
aside from that looks like you have a nice clean and honest motor!! welcome to the zone!
mrlee
snoops
Major Helmet
Post Sun Jan 07, 2007 5:14 pm
yep the wheels look like copies
