Hello all,
The passenger side front door on my 2dr e30 isn't closing.
When i try close the door it just bounces off as the latch on the door isn't closing properly.
Is this a common problem and is there a solution?
Thank you.
N/S front door not closing
BenHar
Sounds as though the catch in the door may have got stuck in the closed position.
Try flicking it to open with a screw driver.
Ben
Ben
redcar
It's stuck in the open position and isn't closing
Even when I try close it with a screwdriver it doesn't latch shut
rix313
It's easy enough to pop it out. I'd do that and have a look at it, give it a birthday (lubricate etc). If that doesn't work pop a new one in.
redcar
Ok cool will do. Thank you
Just realised this thread is in wrong section
