My shiny moredoor with m42
Bandit400
Post Fri Apr 15, 2011 8:56 pm
TPS
Post Fri Apr 15, 2011 9:01 pm
Nice one, theres alot of space between the engine & the rad.!
RustyRuss
Post Fri Apr 15, 2011 9:03 pm
Lovely moredoor! :-)
Russell A Macfarlane
Central Scotland
choppa7
Post Fri Apr 15, 2011 9:20 pm
TPS wrote:Nice one, theres alot of space between the engine & the rad.!
...about the right amount of space for a fan and cowelling I reckon.
Nice 4dr though ;)
1990 318i Lux
CaesarBob
Post Fri Apr 15, 2011 9:29 pm
Is that an E36 M42? The inlet fanimold is wrong for an E30.
'97 E36 B3 3.2 Touring - Alpina-Blau
'15 F32 420d M Sport Coupe - BMW - melbourne-metallic (Sold)
'11 E92 320d M Sport Coupe - BMW-saphirschwarz-metallic (Sold)
'99 E36 328iA SE "Shooting Brake" - BMW-titansilber-metallic (Sold)
'89 E30 325i
Ranchero
Post Fri Apr 15, 2011 9:51 pm
CaesarBob wrote:... fanimold ...
My missus had a dose of that once. I believe the application of yoghurt will sort it out.
choppa7
Post Fri Apr 15, 2011 10:51 pm
Spit your beer out funny :lol:
1990 318i Lux
320iAN
Post Fri Apr 15, 2011 10:53 pm
CaesarBob wrote:Is that an E36 M42? The inlet fanimold is wrong for an E30.
lol .. and that coil (pack) looks different :D
jann
Post Fri Apr 15, 2011 11:50 pm
That a e36 inlet.
How's the cooling with no fan?
Lovely looking bay!
RustyRuss
Post Sat Apr 16, 2011 12:18 am
+1 hilarious lol :-)
Central Scotland
tonybtonyb
Post Sat Apr 16, 2011 11:32 am
Stuninng :!: :D
tonybtonyb
Post Sat Apr 16, 2011 11:33 am
Stunning :!: :D
Bandit400
Post Sat Apr 16, 2011 6:58 pm
lol haha, Ye its the engine from an e36 318is 1995.
mrjonchandler
Post Sat Apr 16, 2011 9:15 pm
Bandit400 wrote:lol haha, Ye its the engine from an e36 318is 1995.
How did you do the conversion? How did the electric side of it work out and the ECU?
Looks great in the engine bay.
What are the results like? This engine is a 1.9 right?
Jon
Bandit400
Post Mon Apr 18, 2011 4:11 pm
My 1.6 was on its way out so thought if im going to do a change why not for this. The change was fairly striaght forward. The m42 bolts straight to the 316i gearbox (although you need to change the spigot bearing 5 min job), the 316i sump needs to be put onto the m42 engine as well as the engine mounts.
The electrics wernt to bad either. I used the e36 318is ecu, but this needs to be a pre 1996 ecu without the ews alarm thing. I then managed to get the wiring diagrams for both the e36 x20 plug and the e30 c101 plug. You will the e36 318is engine harness plug from the e36 car. You car then wire up that plug with the old 316i engine harness plug so everything will just plug together.
I think thats all if you need anyother info just let me know
mrjonchandler
Post Mon Apr 18, 2011 10:02 pm
It sounds straightforward enough, just a case of getting the right bits in advance, it would be the electrical side which would fox me. How does it go now it's up and running. I really like the characteristics of the M42, great engine. Did you do any other upgrades?
Jon
Bandit400
Post Wed Apr 20, 2011 11:22 am
The electrics seem hard but if you have the right info then its easy. I can try and dig out the wiring stuff for you when you need it. It runs brilliantly can't fault it. Sounds nice and rev's cleanly right to the red line. I replaced all the suspension bushes, brake lines and wheel bearing i also put disc brakes on the rear as the 316i came with drums. I've put sport shocks on and 40mm spring. Thats it. Now its just general maintainence and enjoying it.
mrjonchandler
Post Wed Apr 20, 2011 9:42 pm
Bandit400 wrote:The electrics seem hard but if you have the right info then its easy. I can try and dig out the wiring stuff for you when you need it. It runs brilliantly can't fault it. Sounds nice and rev's cleanly right to the red line. I replaced all the suspension bushes, brake lines and wheel bearing i also put disc brakes on the rear as the 316i came with drums. I've put sport shocks on and 40mm spring. Thats it. Now its just general maintainence and enjoying it.
Good for you, i like it. Any info you have would be great. Glad you're enjoying it.
Joj
