- Homo Hair
Theo
Post
Tue Nov 23, 2010 10:00 pm
First things first, get rid of the Trevor logo!
- Homo Hair
Post
Wed Nov 24, 2010 8:53 am
Theo325 wrote:First things first, get rid of the Trevor logo!
I kinda like the Trevor logo..
It had crossed my mind to grind it off though.
Post
Wed Nov 24, 2010 10:22 am
Jhonno wrote:Theo325 wrote:First things first, get rid of the Trevor logo!
Leave it on
I think it looks cool and its certainly different !
Post
Wed Nov 24, 2010 10:28 am
TVR's look cool on the hard shoulder!
maxfield
Post
Wed Nov 24, 2010 10:30 am
Seen more than TVR on the hard shoulder!
But still a cool car and fast when working.
- Homo Hair
Post
Mon Dec 13, 2010 6:28 pm
345mm CSL discs with AP 4 pot inside a 17" BBS RS.. Needs a small spacer behind the disc and one for the wheel. Until the struts are back on the car I am not sure how big though. Or probably work getting hold of an old tie rod thinking about it..
Post
Mon Dec 13, 2010 6:35 pm
Will you be buying new CSL discs?
- Homo Hair
Post
Mon Dec 13, 2010 6:42 pm
No more expensive than new rotors..
170 each from ECP.. How often do you need to buy them either
Cook318IS
Post
Mon Dec 13, 2010 6:44 pm
When are ou spilling the beans on the powerplant of your m3? i'd be tempted to leave tvr on the calipers too
- Homo Hair
Post
Mon Dec 13, 2010 7:07 pm
Unless someone stumps up the cash for my S50, that will be going back in with a few extras..
- Homo Hair
Post
Mon Dec 13, 2010 7:11 pm
What I like about the CSL discs is the floating design and the weight.. for such a large disc they are very light! 8.5kgs iirc, compared to a 330mm disc I was looking at which was 10.4kg.
Duke137
Post
Tue Dec 14, 2010 9:40 pm
Leave TVR on
Morat
Post
Wed Dec 15, 2010 9:41 am
Leave it on, and say that you bought a TVR originally but had to replace the unreliable bits with BMW parts when they failed
- Homo Hair
suchy
- True Zone Relic
Post
Wed Dec 15, 2010 10:35 am
Now that is rather large!! Hope they don't fold the struts under the car when you brake from 150mph at the 'Ring!!
Just out of comparison, what would a standard front hub assembly weigh- I'm talking complete 4-stud with standard braking system- as opposed to the 5-stud upgrade with your new setup?? Just curious
- Homo Hair
Post
Wed Dec 15, 2010 10:53 am
Well if someone wants to weigh a complete (damper/spring/top mount) 51mm 4 stud strut with disc/caliper I will weigh mine to compare. It will be interesting for sure! The disc weighs much less than you'd think and the caliper is very light.. I am running aluminium control arms also. The RS' are a pretty light wheel believe it or not, coming in at 9.4kg, which is less than the M-Systems!
suchy
- True Zone Relic
Post
Wed Dec 15, 2010 11:16 am
Yeah that's why I asked- thought it may not be much heavier (if even heavier at all!!). And if you've fitted alu control arms also you may have less unsprung mass and less rotational force? Should feel pretty nimble on the steering coupled with massive braking force
I'm sure someone will have an assembly they can weigh for comparison...
Rallyprep_UK
- formerly Driftnething
Post
Wed Dec 15, 2010 11:22 pm
awsome !
Will keep an eye on this
Jhonno - How often do you get over to the ring ?
Kos
Post
Wed Dec 15, 2010 11:32 pm
Jhonno wrote:Well if someone wants to weigh a complete (damper/spring/top mount) 51mm 4 stud strut with disc/caliper I will weigh mine to compare. It will be interesting for sure! The disc weighs much less than you'd think and the caliper is very light.. I am running aluminium control arms also. The RS' are a pretty light wheel believe it or not, coming in at 9.4kg, which is less than the M-Systems!
reminds me, i need to square you up and collect them !
i'll bell you over the next few days if it doesn't go spastic at work
Dezzy
- CR24v it's a lifestyle
Post
Thu Dec 16, 2010 9:02 am
Subscribed.
Co Founder of
CR24vTM By Invitation Only. Absolutely no riff raff!!!
- Homo Hair
Post
Thu Dec 16, 2010 10:06 am
Driftnething wrote:awsome !
Only once so far.. Will be going again next year if I can get the M3 built..
- Homo Hair
Post
Thu Dec 16, 2010 10:07 am
Kos wrote:Jhonno wrote:Well if someone wants to weigh a complete (damper/spring/top mount) 51mm 4 stud strut with disc/caliper I will weigh mine to compare. It will be interesting for sure! The disc weighs much less than you'd think and the caliper is very light.. I am running aluminium control arms also. The RS' are a pretty light wheel believe it or not, coming in at 9.4kg, which is less than the M-Systems!
No worries fella, still sat safely tucked away for you
Theo
Post
Thu Dec 16, 2010 10:19 am
It looks like the disc is a bit too big for the caliper?
- Homo Hair
Post
Thu Dec 16, 2010 11:07 am
The caliper isn't seated properly over the disc and the angle of the pic doesn't help.. I will be checking that tonight.
The caliper was advertised for 330mm discs, with a bracket to go bigger supplied if needed, so I reckon they will be ok. Same as the same caliper is used for normal M3's (325 disc) and the CSL (345 disc)..
- Homo Hair
billgatese30
Post
Thu Dec 16, 2010 7:27 pm
Definately think a spacer behind the disk is needed. 14 thou is slightly tight.
- Homo Hair
Post
Thu Dec 16, 2010 9:49 pm
billgatese30 wrote:Definately think a spacer behind the disk is needed. 14 thou is slightly tight.
I think I could shave the steering knuckle slightly to make it clear, however the big issue will be the tie rod.. I will pick up an OEM one, and I have dims of rose jointed ones, and will see if that will help clear. Obviously I'd rather not run a spacer if I can avoid it..!
Post
Thu Dec 16, 2010 9:58 pm
Jeez they are big !
you hoping to lift the rear wheels off the floor during an Emergency stop ?
- Homo Hair
Post
Thu Dec 16, 2010 10:12 pm
To be fair.. They are probably a bit excessive, but why not..
294's for the rear as well.. Only a single pot sliding caliper though.
glenn
- Engine Transplant Services
Post
Thu Dec 16, 2010 10:22 pm
you'll probably have the tarmac creasing in front of the wheels, when you brake with them dan
they look awesome
Post
Thu Dec 16, 2010 10:42 pm
You will never get a standard track rod end on there!
- Homo Hair
Post
Thu Dec 16, 2010 11:01 pm
DanThe wrote:You will never get a standard track rod end on there!
I know..
I just want to see how much spacing would be required, and whether an alternative could be sorted!
Post
Thu Dec 16, 2010 11:17 pm
A rose joint would be perfect for this IMO, no plastic parts though
