pic request. modified arches
SickEddy
hello everyone.
i am requesting pics of modified arches. stretched, flared or something completely different. whatever was needed for very wide alloys. i have got myself some 8.5 and 10j 17inch alloys and they will be going on the car. i would like it to look as standard as possible but post up whatever you have done or seen.
thanks
also would be even better if the pics have a tech 2 kit
thanks
Fal_325i
Sorry mate, can't help with the pics, did see your car coming behind me on Oxford Road a few months back with your xenon's on, I was in my Golf and was going straight over the roundabout you done a left towards Bicester Road ends, car sounded good though.
SickEddy
thanks, miss driving my sport
its off the road at the moment having a 5 stud conversion and e36 steering rack. back in my old 320 zender atm. still trying to get money for an m52 lump but just bought 17inch borbet a's so kinda ruined that lol
jasso
I take it you bought the ones off ebay, i concidered them myself but i dont know if your aware that if you do a e36 rear 5 stud conversion the hub sits 12mm further out so it will get agressive
SickEddy
theyre not the ones from ebay but probably the same thing. i have 9j at the moment. so an extra inch and a half including the 12mm + theyre 17s not 16s...hmm...im still doing it, i will consider anything to get these on the car other than a genesis kit. but i do want it looking as stock as possible
anybody have any pics?
SickEddy
actually the offset is 20 for the new alloys and the 9j were 15 so they will sit further in the arch so that helps. stil will be a big mod though but im sure someone has done it before
jasso
Have you concidered e30 m3 rear hubs and disc's?? or even getting a engineering company to machine out some blank hubs and provided the diameter of the blank hub is wide enough get it drilled 5 x 120
FMH
The wheels sitting in could also be an issue, they will probably catch the inner arch, so you might need spacers and futher flare. What wheels are they?SickEddy wrote:actually the offset is 20 for the new alloys and the 9j were 15 so they will sit further in the arch so that helps. stil will be a big mod though but im sure someone has done it before
FMH
Just to give you and idea of what sort of work you'l need to do.
Heres a few pics i got from the guy who modified the m3 cab rep i'v brought.
These wheels are 10j ET13, bolted onto the normal 4 stud just to see how they looked, after the 5 stud, they came out a further 12mm.
A flare/roll will be no help at all to be honest, you'l definitely need to butcher the arches, maybe adapt some from another car.
With these wheels fitted with the e36 set up, not even the m3 arches could clear them.
Zizzle
SickEddy wrote:hello everyone.
thanks
Here you go mate...
this is sitting on 10's all the way round...
http://www.e30zone.net/modules.php?name ... t=#1655567
SickEddy
the new alloys are 10j et20 17inch borbet a's. will probably be running 245/35 tyres. the front should be ok (not 10j) its only the rears im worried about. at the moment i have 9j 16s and they are et15 so new ones will be a bit further in but then 12mm out after the 5 stud (old alloys are 4 stud) so i dont think they will be rubbing on the inside so shouldnt need spacers. will just be the outside of the car needing mods.FMH wrote: The wheels sitting in could also be an issue, they will probably catch the inner arch, so you might need spacers and futher flare. What wheels are they?
i love that cab. and the arches still look stock. may have to get in touch with the owner and find out exactly what was done and where. borbets too so probably same offset.
and tech 2 kit, main reason i asked for that was to see if the arch needed pulling out nearer the bottom not just the top, if it was done the kit still looks flush all the way.
cheers people
actually how much difference is there between 15 and 20 offset in mm? +12mm out from 5 stud, - about the same from extra width - et5. i think i have around 5mm clearance at the moment ... if its not an easy answer dont worry. this was only a quick thread for arch pics, thanks
FormerMember
Here's my cabrio, factory arches were stretched quite a bit. Now 10" ET14 with 245/35 rubber and 280mm from wheel center to arch rolls nicely without rubbing. Camber is adjusted to -2 deg.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
march109
Flared arches, done with new inner and outer genuine BMW arches both sides. Not too agressive but done to fit some 8j Ketskins without rubbing on a 60mm drop. Picture is obviously with the BBS RMs though.
Heres same car same arches same drop on 7.5J 17inch Alpina reps
Will check on offset of the RMs later today, but they always scrubbed the arches on my last e30. Fit like a glove on this one. Council drop to be removed in favour of 30-45mm over winter.
BMW dont do rear outer arch repair sections, just the inners and whole rear quarters.march109 wrote:Flared arches, done with new inner and outer genuine BMW arches both sides.
Is it a difficult job to flare standard e30 arches?
gooner1
- Out humping Reindeer
Correct, but there are two parts for the inner, the outer innerbss325i wrote:BMW dont do rear outer arch repair sections, just the inners and whole rear quarters.march109 wrote:Flared arches, done with new inner and outer genuine BMW arches both sides.
and the inner inner. That confused me greatly when i ordered
what i thought was an outer arch repair section.
Ended up buying the complete rear quarter as well in the end.
march109
Well yes it was new rear quarters, and rear bumper and rear lights and rear slam panel boot floor ect ect, all courtesy of the silly tart that ran up Adams backside when he owned the car, have reciepts for it all.bss325i wrote:BMW dont do rear outer arch repair sections, just the inners and whole rear quarters.march109 wrote:Flared arches, done with new inner and outer genuine BMW arches both sides.
The whole rear end is just 7 years old this winter. The only thing that pisses me off is they only painted the rear and not the whole car, and if your anal like me you notice the colour difference quite a bit. Someday I'll do it properly since I need a new sunroof panel and front wings.
- E30 Zone Meets/Events Team
Did you use spacers for the ~RM's, just too clear it up for others, as some say you need them and some say you don't.march109 wrote:Flared arches, done with new inner and outer genuine BMW arches both sides. Not too agressive but done to fit some 8j Ketskins without rubbing on a 60mm drop. Picture is obviously with the BBS RMs though.
Holy smoke! I'm surprised that didn't write the car off as that wouldn't have been cheap!march109 wrote:Well yes it was new rear quarters, and rear bumper and rear lights and rear slam panel boot floor ect ect, all courtesy of the silly tart that ran up Adams backside when he owned the car, have reciepts for it all.bss325i wrote:BMW dont do rear outer arch repair sections, just the inners and whole rear quarters.march109 wrote:Flared arches, done with new inner and outer genuine BMW arches both sides.
march109
No spacers ever. Don't like them. Wouldn't have the RMs if I needed them, I'll check the offset later today like I said. But they work fine without them and I've no reason to see why anyone would unless the offset was cack. But FFS buy the right ones in the first place.
march109
Twasn't (is that a word?)bss325i wrote:Holy smoke! I'm surprised that didn't write the car off as that wouldn't have been cheap!march109 wrote:Well yes it was new rear quarters, and rear bumper and rear lights and rear slam panel boot floor ect ect, all courtesy of the silly tart that ran up Adams backside when he owned the car, have reciepts for it all.bss325i wrote: BMW dont do rear outer arch repair sections, just the inners and whole rear quarters.
But if you remember Adam at all you'd know he liked to put his hands in his own pockets quite a bit. I had 3 folders of receipts and invoices off him when I bought the car.
Wasn't done at a BMW delearship though, local independant bodyshop that I know rather well due to a few other smashes.
SickEddy
when everyone says doing a 5 stud will push the wheels out 12mm from 4 stud, is this just the front or at the back aswell? thanks
FMH
Only the rear.SickEddy wrote:when everyone says doing a 5 stud will push the wheels out 12mm from 4 stud, is this just the front or at the back aswell? thanks
SickEddy
thanks, anyone with 5 studs please can you put up your alloy width and offset? thanks
