update.
turns out the old block had early pistons so it was a high compression one ,
no wonder it was so nice.
anyway.
update #1.
compression test after dyno runs shows weak #6 cyl (8bar) while all the other ones where 12-13bar
update #2.
turbo is in the works.
Stage III from TCD ( T40E 60trim ) and TCD top mount manifold
I´m going to be running 1bar on a M20B28
M52 crank
M20B20 rods
M20B25 pistons (late)
ARP headbolts
Stage III TCD/UUC clutch kit (450lbs + )
TIAL 38mm
TIAL BOV
Well sized intercooler
42lb injectors
VEMS
"3 downpipe, exhaust and inline silencers.
Compression is 9.16:1 which will suit perfect for the level of boost and normal in town driving.
HP shall be 400hp and torque 400lbs
full boost by 3k in the last 3 gears, probably slightly later in the first two.
Some pics from the block work
this is a E34 block so I´m going to be drilling for the dipstick.
I´m also working on making the TCD manifold + TCD turbo work without an adapter to fit RHD vehicles. It´s very close
here are a few from when I was working on the first head.
We do what then??
After a quick look at the ports and comparison to the burn pattern on the outside of the exhaust ports they are a very solid source of more air flow. As per alpinas own modifications.
No mods will be done to this 2.8 port wise.
