Cooks m52 316i - going S54!
eko
Old timer
Post Tue Apr 20, 2010 6:26 pm
60/40 drop is fine for an M50 so will be ok with M52 :D
Cook318IS
Post Tue Apr 20, 2010 8:58 pm
i'll be going for 35mm all round i think. But then is it worth going for iS rated springs becuase of the weight of the aluminium block.
It drives very nicely. Its so much quiter inside than the non vanos was... until you give it some shite! Although with the 3.64 lsd it struggles to put the power down
Cook318IS
Post Sat Apr 24, 2010 1:49 pm
Yesterday i put the rear bench back in and... *drumroll* the drivers seat back in!! :banana: Its so much nicer to drive with the recaro, so comfy and supportive! I went out for a few photos again last night too.
Much better :) (the car isnt pink though its just the camera flash)
my new laptop background now!
you can just see the sump saying hello from underneath the car :chuckle:
tez180
Post Sat Apr 24, 2010 1:55 pm
Awesome car cook! - looks fantastic.
Accord Type R
245 Whp
Looks great. Leather Recaro's :wan:
Cook318IS
Post Sat Apr 24, 2010 1:58 pm
Cheers guys :) I've had alot of people stopping to look at and commenting on how well the engine suits the car and how clean it looks now.
Dezzy
CR24v it's a lifestyle
Post Sat Apr 24, 2010 2:09 pm
Very nice matey.
Loving the backdrop. Just needs that arch gap sorting. :cool:
eko
Old timer
Post Sat Apr 24, 2010 7:56 pm
Looks totally different with a shine :cool:
Post Sat Apr 24, 2010 8:40 pm
Dude you need more than 35mm!!
Looks good (other than the monster truck ride height..)
Cook318IS
Post Sat Apr 24, 2010 8:47 pm
It's on touring springs jhonno...
Fronts are the same as 2/4dr though..
Cook318IS
Post Sat Apr 24, 2010 8:48 pm
You sure? I think it's slightly higher than normal
springs.
Post Sat Apr 24, 2010 8:49 pm
Not as far as I am aware.. My 325i Touring sat about the same as a Sport does iirc
Dezzy
Post Sat Apr 24, 2010 9:11 pm
My chromie is 35mm on H&R's mate
I have come round to Jhonno's way of thinking. I have ordered 15mm lower tophats for the front and will sort the rears with 60mm springs and a 10mm spacer. :D
Cook318IS
Post Sat Apr 24, 2010 11:24 pm
hmmm, i'll have to see what its like on the iS springs first! the huge speedbump getting into college is what gets me worried. It HAS to be illegal, its fookin huge!
Post Sat Apr 24, 2010 11:29 pm
Get it sitting nice and low kids :)
Cook318IS
Post Sat Apr 24, 2010 11:31 pm
not a word of a lie, you wouldnt be able to get over the speedbump getting into college. At least they have a nice hairpin into the student carpark which is normally greasy...
Post Sat Apr 24, 2010 11:43 pm
You'd maybe be surprised.. I have to tackle some substantial ones to get into work..!
Dezzy
Post Sun Apr 25, 2010 6:11 am
Jhonno wrote:Image
Chromie's don't need to be that low. They don't look right slammed. Facelifts need 60/40 IMO.
Jhonno the wheels on it now look miles better than that picture. winkeye
Post Sun Apr 25, 2010 11:39 am
Fab pics, what camera have you got, i want one :D
Ps Kami is using your sig pic :roll:
Post Sun Apr 25, 2010 11:53 am
Dezzy wrote:Chromie's don't need to be that low. They don't look right slammed. Facelifts need 60/40 IMO.
Funny enough I think the Chromies need to be lower to compensate for the rear arch :D
Dezzy
Post Sun Apr 25, 2010 12:06 pm
Level not lower IMO 50mm is about right.
The rears need to be lower than the facelifts for that reason though. :D
stup86
Post Sun Apr 25, 2010 3:34 pm
Jhonno wrote:Image
What suspension you using Jhonno?
Parts needed:
M40/M20 ignition coil with high voltage lead
Cook318IS
Post Sun Apr 25, 2010 5:41 pm
Alex, the camera is a canon 400d with either the standard 18-55mm lens or my 50mm prime (fixed) lens. I have noticed kami's sig too, i have asked him about it and he says hes found it on google... funnily enough i have one identical on my photobucket. I'll be asking for the mods to remove it if he doesnt give me the link of where he found it.
I suddenly had a problem with the clutch on friday out of the blue. With the clutch all the way to the floor it was catching/rubbing on something :? Anyway a few pm's to danthe and i took a trip to euro car parts to buy a new master cylinder (becuase it needed doing anyway) and an e36 m3 3.0ltr clutch slave cylinder. ECP didnt have the slave so a quick argument with gsf and i soon left with a slave cylinder. Now this is where it all goes downhill... :cry:
Fitted the master and slave cylinder (which isnt easy anyway!) About 10 pumps on the clutch when we started to bleed it and... BANG followed by the gearbox urinating all over the floor. The fucking slave cylinder popped for no apparent reason. managed to remove it and preyed that nothing stayed in the bellhousing. Rebuilt the old slave cylinder and put it all back together again. Bled absolutely lovely. drove it down the road and you can hear something tinging around inside the bellhousing :cry:
Removed the starter motor and the slave cylinder again to try and fish whatever it is out. No luck so it means that the bastard gearbox has to come out :x I'll be on the phone tommorow to buy a genuine bmw slave cylinder regardless.
Fairly pissed off with it now.
Post Sun Apr 25, 2010 6:18 pm
Dude! I did EXACTLY the same thing.. You didn't locate the slave rod properly, as you've bled it up it's blown itself apart as it had nothing to press against..
I would suspect it is a spring, assuming you fished the rod out... It's an utter pisser. Took 1/2 day to pull the box and fish bits out before putting it back together again :cry:
I feel your pain!
Cook318IS
Post Sun Apr 25, 2010 6:20 pm
i thought that if the rod wasnt located properly it would of done it straight away? it was alot of pumping before it did it
Post Sun Apr 25, 2010 6:26 pm
Mine was exactly the same.. Lots of pumping, thought it was nearly there then pop :cry:
eko
Old timer
Post Sun Apr 25, 2010 6:30 pm
Jhonno wrote:Dude! I did EXACTLY the same thing.. You didn't locate the slave rod properly, as you've bled it up it's blown itself apart as it had nothing to press against..
I feel your pain!
This is exactly what I suspect I did :cry:
Thing is the slave is such a tight fit between the tunnel and gearbox there isnt really any room to make sure the rod is located properly before bolting the slave up tight!
The rod came out fine and the spring was still there too,I suspect the bit floating around the gearbox is the ballsocket thing the the rod sits in :cry:
Back out with the box tomorrow :cry:
mr_dink
Post Sun Apr 25, 2010 6:50 pm
Gutted about the slave cylinder, the car's looking really good though :thumb:
Regarding the suspension/speedhump discussion a couple of pages ago, I would say definately go 60/40.
My 2 door is lowered 60/40 and I can get over a wide range of speedbumps without scraping (without passengers that is!)
We have some bad speedbumps in Nottingham and I know several guys running -60mm and lower with no problems.
Just go over the bumps as slowly and diagonally as possible and you should be fine. Sumpguard is recommended though!
Cook318IS
do you have a 24v engine too?
Baz666
Post Sun Apr 25, 2010 6:54 pm
Nice work there fella, thinking of an m50 myself now for my touring. :cool:
mr_dink
Post Sun Apr 25, 2010 7:03 pm
Cook318IS wrote:do you have a 24v engine too?
That's a good point, I don't (yet) have a 24v in there, that was with an m42. Most of the mates I mentioned are running m20 anchors though.
It's personal choice at the end of the day, I'm just saying that speedhumps aren't impossible.
What setup would you go for if it wasn't for the big bump outside college?
Cook318IS
Post Sun Apr 25, 2010 7:05 pm
24v engine sumps sit lower than the normal e30 sumps you see. I was going to go for 60/40 originally but then alot of people said that it would be too low for a e30 with a 24v engine and i dont fancy risking the sump tbh!
Post Sun Apr 25, 2010 7:15 pm
Ive not had one go bang but I have managed to drop the push rod into the bellhousing before, nasty, got it out with a telescopic pen magnet thing and some very long bent pliers.
Taking an M52 box out of an E30 is not a nice job :(
Had a similar problem before on a different car and used a hole saw through the bottom of the bellhousing and a nice fitting bung afterwards :wink:
mr_dink
Post Sun Apr 25, 2010 7:18 pm
Cook318IS wrote:24v engine sumps sit lower than the normal e30 sumps you see. I was going to go for 60/40 originally but then alot of people said that it would be too low for a e30 with a 24v engine and i dont fancy risking the sump tbh!
Ah, I didn't know that. Wasn't really planning on changing the springs on mine. I'll report back on how low the sump is (iron block m50, -60mm) in a couple of weeks once I've pulled my finger out and got the lump in!
