My e30 4.0 v8 Drift Project - Wisefab lock kit, BC Coilovers
GB69
Sat Nov 23, 2013 4:41 pm
**** update 23 November 2013 ****
Exhaust Manifolds now done, Y piece fitted, and Middle Box now in. No Backbox yet, that will be done after the new bodykit is received and fitted. I had a retard moment, thinking the only adjustment on the BC coilovers was to compress the spring, then found out about adjusting the lower nut and so ride height was raised 30mm as it was too low. Brake Servo relocated to under the passenger side dashboard. A Brake Bias Valve was fitted into the rear lines, then into the Hydro. Brakes done, and bled and so the customary Burnouts commenced.
Burnouts:-
[youtube][/youtube]
Could prob do with going a little lower.
GB69
Sat Dec 14, 2013 9:20 pm
Its almost ready to be painted, so I have booked to do New Years Eve Drift day at Teesside Autodrome.
Cant wait to kill a few tyres. Then next year, it will be MOT'd and Taxed. ;)
Sat Dec 14, 2013 10:30 pm
i'm up for some wristband action when you've teethed it 8)
GB69
Sat Dec 14, 2013 10:35 pm
magpie wrote:i'm up for some wristband action when you've teethed it 8)
No worries, jump in if you're brave enough. lol
Sat Dec 14, 2013 10:37 pm
no sense no feeling :mad:
sunnysr
Tue Dec 17, 2013 9:15 pm
looks hellish, i will probs come down to the track on newyears eve so hopefully will see it in action. Thats exactly how my hotrod left the garage doing a huge smokey burnout ...its the only way.
where did you get the wide arches, im having a nightmare finding any only ever seem to come up with m3 arches or ones like yours but for a fortune.
GB69
Tue Dec 17, 2013 9:35 pm
Arches are on ebay. http://www.ebay.co.uk/itm/200994402071
I'm looking forward to getting it on track.
Tue Dec 17, 2013 9:57 pm
what time you gonna be at teeside on nye ?
GB69
Tue Dec 17, 2013 10:06 pm
prob be there from 8am, track opens at 10am.
GB69
Sat Dec 28, 2013 10:50 pm
**** update 28 Dec 2013 ****
Since the last update, its been painted, and almost completed, just had photoshoot done and had a bit "practice".
Testing the fitment of the new bodykit
Then stripped it all off, preparing for paint
Then did a photoshoot
Then had a little "practice".
I'd drove it more in reverse than I had forwards before this video. lol
GB69
Sun Dec 29, 2013 7:21 pm
2 more Video's from the practice session.
3rd gear Donuts and Figure 8's.
Mon Dec 30, 2013 12:47 am
I spy a beardy walrus :D
Mon Dec 30, 2013 9:59 am
DanThe wrote:I spy a beardy walrus :D
:squint: ........... :)
he took the pics and looks like he's nicked some advertising space on the rear bumper lol . he's in the middle of the track tomorrow with the media/magazines etc lot wearing a high vis jacket so should be fairly easy to hit
:snigger:
GB69
Mon Dec 30, 2013 10:10 am
I hope I dont hit him, I'd destroy the car. lol
Tue Dec 31, 2013 9:18 am
today's the day mate,see ya down there 8)
sunnysr
Wed Jan 01, 2014 6:00 pm
Didnt get down there but just seen this pic on facebook , looks like fun was been had
GB69
Thu Jan 02, 2014 10:22 am
Yeah it was an awesome day, the car went very well, got a couple of things to sort out but nothing major. Checked the lock before hand, and nothing hits anything, but found on track wheel hits either the wishbone or chassis preventing full lock and acting like a brake on that wheel making me spin. So either need a 20mm spacer or better offset wheels.
I was also drifting with a flat drivers side front tyre for most of the day without realising it. Destroyed a wheel, and can only think it must of been done on west track on my 3rd lap as thats only time I cut a corner.
I learned you just cant put 300bhp thru 205/55/16 tyres with 2mm tread in the wet. 4th gear from 3k revs effordless drifting.
Here's a few Video's
Notice the flat tyre lol
Pictures.
Looks like bits of wheel behind me.
4th gear even in the wet produces smoke.
Oh does anyone know what temperature its supposed to run at? I'm using almost 100% Antifreeze, got 2 digital temp gauges, 1 as water enters the radiator which was often showing 105c, and other on exit of radiator show under 80c. I heard these run hot, but kept thinking over 100c is too much even tho 100% antifreeze wont boil til 150c.
Thu Jan 02, 2014 12:57 pm
Looks reet council :)
It will probably be the antiroll bar touching the tyre
100% antifreeze wont be doing you any favours at all, 50% max
GB69
Thu Jan 02, 2014 7:25 pm
DanThe wrote:Looks reet council :)
Council people couldn't afford this mate. 8O
What Antiroll Bar, I aint got any at all. lol
100% antifreeze was recommended to keep temps/pressure down when drifting at high revs.
I'm think I need to take the temperature reading from the centre of engine, maybe the allow block thing at back of engine as I would assume taking the temperature as it enters the radiator will be the hottest place possible, so 105c could be normal there, but much less elsewhere?
ross_jsy
Thu Jan 02, 2014 7:44 pm
You don't want to be using 100% antifreeze. No one does in real motorsports
pianist
Thu Jan 02, 2014 10:51 pm
Anyone tried EVANS waterless coolant?
http://www.evanscoolants.co.uk/
Just wondering if anyone has tried it and could recomend, cause it looks like a good stuff, has a boiling point at 180 degrees thus no pressure in the system and no steam pockets in cyl. head
GB69
Thu Jan 02, 2014 11:32 pm
Its really expensive, Japspeed cars use it in BDC, £65 for 5 litres, v8 takes about 11 litres I think.
Looks like I got the 100% antifreeze wrong, as antifreeze makes the engine run hotter. Best cooling is 100% water, 50/50 mix is about 12 degrees hotter than 100% water. Also I'm using a 1.5 bar radiator cap, so 100% water wont boil til it gets to 112c. So looks like I might try 100% water, and see what the difference is.
Fri Jan 03, 2014 12:00 am
Corroded engine internals and premature failure of the water pump bearing.
rix313
Sun Jan 05, 2014 1:44 pm
I'm not a fan of the Evans stuff we had all sorts of problems when running it at the Silverstone 24 in a Mosler.
Mon Jan 06, 2014 4:43 pm
found this vid ....goes on board with you @ 1.50 in 8)
[youtube][/youtube]
GB69
Mon Jan 06, 2014 6:12 pm
Yeah its a good video. Looking at the videos and pics I was doing quite well. Surprised at some of the speeds I was getting out of the last corner. Didn't feel like it when driving, but it was 4th gear around 6k revs. lol
GB69
Mon Apr 14, 2014 9:58 am
Still having slight issues with wheel rubbing the wishbone preventing full lock
So I added a spacer to the front wheels.
Had a bit of a test session yesterday on private land.
GB69
Wed Jun 04, 2014 7:20 pm
This now needs an update after last weekends Extreme Torque Show.
I had a "little off" lol during the practice session, 4th gear 5k revs ish, rear hit fence bring the front in which only glanced the fence as rear sprung round again ending up in a ditch.
Done quite a lot of damage:-
However the main rear beam mounting points appear to be fine and not been moved.
To make it driveable again, aslong as the mounting points are fine I need rear trailing arm for 5 stud, and a driveshaft which snapped. The rest can be pulled/cut out replaced and reinforced. It really needs a reshell, which is my longterm plans for it, but for now hoping to simply get it ready to skid again as a missile car. ;)
GB69
Wed Jun 04, 2014 7:21 pm
I replaced the rear trailing arm and driveshaft yesterday, so now the car is moveable and skidable again.
Looks reasonably straight.
Kicked the passenger door open, not it wont close lol
More photo's of the crash have appeared.
I hit the drivers side rear quarter on the fence in 4th gear at 5k revs. Not sure if driveshaft snapped mid corner or during the crash.
These pics show what happened next.
appletree
Wed Jun 04, 2014 7:34 pm
Shame but, suppose if you do drifting for long enough the inevitable happens beit through mechanical failure or going past the limit.
As you say it needs a reshell but aleadt you have it drivable again and some argue when you know something is fooked you have more fun with it because your not scared of scratching it. :D
GB69
Wed Jun 04, 2014 7:38 pm
Yep its getting reshelled, not taking the risk competing again with this car, that's a lot of damage and I'd rather be safe. Quite surprising that I got out the car without a mark, not even a bruise.
Thanks to Magpie on here, I will have a 2 door iS shell very soon.
Wed Jun 04, 2014 8:11 pm
let the games begin :D
initial_g
E30 Zone Moderator
E30 Zone Moderator
Wed Jun 04, 2014 9:44 pm
Great work looks sounds and goes well, I used to hate drifters for crashing & ruining e30s but love you guys now... 30's are getting rarer and rarer every season send the prices ^ haha! On a serious note though love the car and the thread and will be following this one :cool:
_Jay_
Fri Jun 06, 2014 3:17 pm
Love the project, shame about the off but at least you walked away unhurt! And good to see your carrying it on and not losing heart in it! Look forward to seeing updates!
Gok
Sat Jun 07, 2014 9:12 am
Glad you came out of it unharmed. Metal can always be replaced.
