I to will be on the hunt for a rot free 2dr prefacelift shell in a couple of months, lets just hope i'm as lucky as you!
Keep the pics coming.
Nnnnnnooooooooooo...................Kedge wrote: all the chrome has vanished.
No chrome will be harmed in the making of this car, just removed!The_Diddler wrote:Nnnnnnooooooooooo...................Kedge wrote: all the chrome has vanished.![]()
You painting the chrome bodycolour i presume then
In that case then is any of the chrome for sale, cheky aint iKedge wrote:Cheers Lee
You painting the chrome bodycolour i presume then![]()
Although it is prooving hard to find a non chrome rear bumper
PM sentThe_Diddler wrote:In that case then is any of the chrome for sale, cheky aint iKedge wrote:Cheers Lee
No chrome will be harmed in the making of this car, just removed!The_Diddler wrote: Nnnnnnooooooooooo...................![]()
Although it is prooving hard to find a non chrome rear bumper![]()
That has crossed my mind ages ok but then i'd forgot about doing that. Possibly going to be a little less involved and give me better management. Just got to make sure TDC is set correctly on the front pully haven't i? Should be easy enough to get all the parts quite cheap shouldn't it as wellDanThe wrote:Why dont you change the loom/ECU to a later type? You wouldnt need to take the gearbox out at least
I'm from Coalville but use to work for BT at Cardinal Tower, the big all buidling opposite St Georges so there's a good chance you'd have seen it, sold it Aug '08 though. do miss it at times. Whereabouts are you, wouldn't mind seeing your iS sometime!pac1982 wrote:I like that looks nice, only just noticed you’re from Leicester Kedge where about are you think I may have seen your red IS near St. Georges retail park a few times???
I live in Thurnby but spend a lot of time over in sileby as that’s where the girlfriend lives if you ever see me around give me a holla i’ve got a White IS with German style plates starts with H702Kedge wrote:That has crossed my mind ages ok but then i'd forgot about doing that. Possibly going to be a little less involved and give me better management. Just got to make sure TDC is set correctly on the front pully haven't i? Should be easy enough to get all the parts quite cheap shouldn't it as wellDanThe wrote:Why dont you change the loom/ECU to a later type? You wouldnt need to take the gearbox out at least
Which is worse?Kedge wrote:Very rarely in Leicester these days as i work in Birmingham these days
Going on the fact i work in Small Heath and not the city center, Birmigham by a mileDanThe wrote:Which is worse?Kedge wrote:Very rarely in Leicester these days as i work in Birmingham these days
