Thanks for the nice comments. Its out of a supra 2JZ-GTE engine, Approx 3.1l single turbo garrett gt4094r and yep its been off the road for a while...Ad-E30 wrote:Wow! That is some serious engine work. What car was the 3.0litre out of in the first place?
What's she like to drive or have you just gone for more brute power? lol. Is that running twin turbos?
Its been 10 months since your last post, has she been off the road much of the time?
Colour is spot on also.
330Ti Finally back on road :)
g57yle
- Boost Junkie
Fal_325i
WOW!, I am speechless, that is an awesome bit of kit, its got the show and the go.
Kos
nah, what that car really means is, "tha yamisso do shisto sou"madaboutthe30 wrote:
But as the greeks say "Me tov vou sou!"....basically be about your wits, as with power like that, its not difficult to go wrong
kam325itouring
Looking good Gary, glad to see it back on road!!!!!
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
m_jermyn
Get some vids up man..
Love the care mate
Mike
Love the care mate
Mike
g57yle
- Boost Junkie
Cook318IS
Holy fucking shit!
that took alot of force to do that much damage!
Well done squire!
Well done squire!
g57yle
- Boost Junkie
didnt like dropping down to 2nd gear, lol
Tyres must have some serious grip for the prop to wind up like a spring as opposed to it locking up the rears. F*cking awesome!!!!!
gareth
nice work
Greeny
Love the arches and the brake light in the boot is
Gone but not forgotten.
('92 325i Cabriolet)
e30-2jz
know what you are talking about, very nice build by the way!g57yle wrote: well anything you can think of had to be custom made to fit. and i mean everything, from mounts to wiring, to moving brake cylinders, from power steering to diff, prop, gear stick placement, fueling, ecu, absolutely everything.
But this is what you get once all the hard work has paid off, well not really finished yet but very close![]()
I hope my E30 gives inspiration to all the other E30 owners to not give up and what can be achieved with a bit of hard work and time.....and some more time..............and maybe some money and more time.......... LoL
i used the stock supra axle, much thicker and massive
mine is still sort of stock, compared to your one hehe, i only swapped original JDM stock twins to US twins and a little bit more boost.
what M5 diff did u use by the way, e34?
Steve
Very nice, any more photos e30-2jz?
webmaster@e30zone.net
g57yle
- Boost Junkie
I Like yours, it must be really nice to drive, with mine your constantly fighting for your life! what box are you running, looking at the prop looks like either a 5 speed or n/a auto boxSteve wrote:Very nice, any more photos e30-2jz?
What did you do with your brakes? Any more pics?
e30-2jz
i'm running a r154 5spd from an mk3 turbo with a 1jz flywheel, i had brembo brake disk's (front and rear) with very soft brake pads, for normal driving its enough but not with 160km+, so i'm busy on making a new set with peugot 302mm disks and 740 brakes,
everyone can buy from 300mm.de but i want to make it myself.
i used a old 7series hydrolic booster, because there is just no space for a conventional brake booster
stock exaust look! i just love sleeper style
making the rear axle adjustable with -60mm lowering
just to many pic's, if request i'll look for it
my winterproject, this one comes in an other e30, Lexus V8 1UZ-FE with 5spd manual!
sorry g57yle for ruining your topic
g57yle
- Boost Junkie
more pics of your brake setup if poss, i have the same setup and im going to probably be installing it this weekend, just need to find the space for all the parts. are you running abs? if so does it work properly?
e30-2jz
best i got right now
no abs, i got no space for that.
it's simple to make it work, abs is a stand alone system
g57yle
- Boost Junkie
are you running a oil cooler for all this?
highlander112001
fcuk******me
awsome car mate
awsome car mate
e30-2jz
little one, not a real cooler but it's doing fine.g57yle wrote:are you running a oil cooler for all this?
there is no fluid spooling true the brake booster when you are not braking, and the fluid in the resevoir is also not spooling so you only cool the fluid that is flowing by for the steering rack.
so if you want to mount the cooler for your brake system it has no use
TouringTash
Wow these guys are pushing boundaries galore. Just the sitting down over a cuppa or three and working it all out is way beyond me. Just what did happen to British engineering if guys can knock this level of work up. OK the challenger 2 is the best battlefield engineering going but what about the rest of the country we don't even make moulded 3 pin plugs.
These cars have given me food for thought just wish my engineering and driving skills were up to it.
Fair play to ya guys
318i Touring
g57yle
- Boost Junkie
Thanks, i installed it a few weeks back, although i had no space at the top so i installed thee splitter under the inlet manifold near the brake bias valve, now i have decided to install an udjustable bias valve, good luck to me getting it out! lole30-2jz wrote:
Brakes feel a LOT more powerfull with the brembos and the hydraulic booster, only things are, with this setup it feels more spongy until the brakes touch the disks, a bit like the mclaren slr
e30-2jz
think you need a bigger master brake cylinder for that spongy feeling, witch diameter are you running?
is your pressure "ball" new? these things are almost always broke. if in good shape you can go with turned off ignition still brake for like 10 times with boosted brakes, if not its broken
do you have "nr 16" installed? you have to use this one if you are running abs
g57yle
- Boost Junkie
Im running the master cylinder that came with it. 25mm so that should be fine, im pritty sure the brakes loose power the second the engine switches off. im pritty sure that 16 is installed.
e30-2jz
25 should be good yes
im sure the Pressure accumulator has loose his power, you better get a new one
that also give strange pedal feeling because you don't have a buffer
http://cgi.ebay.de/BMW-E32-E28-E24-E23- ... 4cee0989bf
glenn
- Engine Transplant Services
wow,
just stumbled upon this thread, respect !
good work
good work
pandaa
kam325itouring
Gary everytime i see this ride i
!!! I'm hoping to get some thing close in mine soon but im sticking to a beema lump.
Zizzle
I wonder how long it will take people to notice this...
