'86 316 M20B28
Meatballs82
Post Thu Nov 15, 2012 1:08 pm
Duke137 wrote:
Meatballs82 wrote:
Kedge wrote:Strange how a dear competitor of yours got them on next day delivery from Febi :mad:
They probably sent a van direct to Germany to collect them :mad:
I wonder if they have an E30zone trade account.... :P
Pipe down you!!!! winkeye
Kedge
Post Fri Nov 30, 2012 11:53 am
The engine build is under way, dropped it off at Dans last week. Still waiting on a few parts but we've got most things together now. Took Schrick 2 weeks to eventually despatch the cam and springs, despite saying they'd done so the day they recieved the money from the dealer I'd used, apparently that kind of thing is common place since being taken over.
Anyway, the engine is now stripped down. Dan's suspects the noises I could hear were some heavily work eccentrics adjusters on the rockers so now a set of those are on their way. The only other thing he's found is some light scoring to the piston skirts, most likely a combination of poor oil a debris in the oil, these have been measured up and are still ok to use which is good news as it feels like I'm bring the country out of recession on my own at the moment :)
The head has been tested and is all good which is always a huge relief with these things. Pressure tested, re-faced, chemical cleaned, exhaust guides done, re-seated the valves and a vac test. Headwork is being kept to a minimum for the sake of reliability, all that we're going to do is get the the gaskets, head and manifold ports matched up to each other so there's no steps. If I feel the need I can get another head done to a lairy spec at a later date.
Time for some pictures;
I'm also going to be going down the MAF conversion route, probably stick to the standard AFM until it goes for a proper mapping session though. Everyone knows about the Miller MAF conversion, however I wasn't keen and the price of it so I'd been looking into what parts could be used for a DI attempt when Mikey_Boy told me he'd got a Miller Gen III he wasn't using along with a BMC CDA airfilter so a price was agreed and that turned up the same day as the cam 8)
Obviously I've seen the issues Si13 has had with his Schrick cam so I pulled it out the box to check and there is only the one slot in the end.
Instagram - Kedge85
blackE30indy
Post Fri Nov 30, 2012 12:52 pm
Ooh shiny parts :D
Post Fri Nov 30, 2012 7:56 pm
Nice work Dave :cool:
Kedge
Post Thu Jan 10, 2013 7:05 pm
Got back in the garage today to crack on with the floor. After the discovery of the surface rust under the sound deadening in the drivers side footwell I tackled the passenger side.
I'd bought one of those oscillating multi tools before Xmas and that was perfect for getting under the sound deadening. However it turned out to be a pointless exercise as the passenger side was perfect so I only took up the front half, should've guessed since the drivers side pulled up by hand whereas the passenger side was still stuck solid.
This was 10mins work with the OMT.
Took a whole lot longer with more scraping and grinding to get to this so I've got a good surface to repaint.
Drivers side took a lot more work though, especially with the added trickery of the throttle pedal mount and stop. After much contortionism it got it to this standard.
Found I had to go quite a way up the bulkhead as well as despite looking fine this section had surface rust under the paint all the way up.
The floor has now been doused in Fertan as I won't get back on it until Monday at the earliest. I'll be fitting new plastic bungs but prior to that the the Waxoyl probe will be stuffed into the holes for a good soaking.
Instagram - Kedge85
Post Thu Jan 10, 2013 7:22 pm
Awsome Stuff :cool:
blackE30indy
Post Thu Jan 10, 2013 7:23 pm
Looks great mate,it's getting there :D
Kedge
Post Thu Jan 10, 2013 7:55 pm
Alex, did you get my PM about the MAF?
It's a slow burner Indy :-) Looking forward to a ride in yours sometime this year :wink:
Instagram - Kedge85
Post Thu Jan 10, 2013 7:57 pm
Kedge wrote:Alex, did you get my PM about the MAF?
I did yes sorry, been off the zone for a month and a bit been out in South Africa.
Ive not got a 2.5 now so wont be doing it, wish i had one as i'am curious to see if it would of worked.
Prehaps i should just drop a 325i auto engine and box into my touring :D
Post Thu Jan 10, 2013 8:50 pm
There would appear to be a queue :D
Kedge
Post Fri Jan 11, 2013 8:17 am
No worries, I'd not been on here for about a month either.
Now we know the Bosch part they use for GEN III I think you'd have got it working fine, much simpler than what you'd found regarding the erlier versions.
You must be bored of M40 auto power by now :wink:
Instagram - Kedge85
polsta
Post Fri Jan 11, 2013 1:48 pm
Kedge wrote: Image
good thread kedge
see bits like this, is it all removable with engine in the car ? how easy to do and put back ? im taking for a complete non mechanic
thats the sort of thing i need to be getting done along with rocker and inlet
Jim320i
E30 Zone News / COTM Team
Post Fri Jan 11, 2013 1:58 pm
All nuts and bolts Polsta, everything that is removable in the engine bay is pretty much covered on the wiki. You'll need basic kit, spanners, socket set and a jack to get the bits pictured above off. (The jack is for the engine so you can remove the mounts.
polsta
Post Fri Jan 11, 2013 2:21 pm
cool cheers jim, got all the tools bar a jack, il leave the mounts for now as engine will be comming after its taken off the road at end of the summer , but i want to do a bit of a bay refurb before this summer to bring it in tone with the rest of the car, shes going to be back soon, paint next week 8)
scott180gtb
Post Fri Jan 11, 2013 2:46 pm
Kedge wrote:Been very little activity since chopping the hole into the floor, been doing training courses and stacks of overtime while i've still got a job. Got a couple of hours on it this afternoon to build up the crossmember;
Just sent off what i hope to be the last parts request from Cotswolds for the underneath including E28 M5 engine mounts to try and shift the engine over enough so the steering linkage has more chance to clear the manifold, fingers crossed it works.
Has this worked. I'm close to selling my BTB2 so that I can run a club sport rack.
Have you started another thread showing the clearance ?
Excellent build and good to see that the rot is getting cut out.
I'm a little confused though. How the hell have you managed to convince Dan to work on an M20?
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Duke137
Post Fri Jan 11, 2013 2:48 pm
He has ditched it Scott and ordered BTB3
scott180gtb
Post Fri Jan 11, 2013 2:53 pm
I think you can order just the rear section of the BTB3 for about £400. I cant remember if you have to order a new balance section as well.
Kedge let us know what you have done. :D
Cars
Kedge
Post Fri Jan 11, 2013 3:24 pm
I've gone BTB3 Scott, I wasn't happy with the clearance being enough during spirited cornering on top of the fact it raised the engine so much, there was a thread somewhere with picks and a few people expressed reservations as to whether there was enough space.
The difference between BTB2 & BTB3 is the front section but it is £350 to £400 for just that section (can't remember exactly), since the BTB2 was free on a doner car I stumped up the cash but if it had to be one or the other the rack will give much more pleasure! I've got an ultra rare RD 6 Branch sat at home as well which won't clear the rack either :(
scott180gtb wrote:I'm a little confused though. How the hell have you managed to convince Dan to work on an M20?
It must either be the involvement of an M52 part to help keep his sanity or that some people really will do anything for money! :D
Instagram - Kedge85
scott180gtb
Post Fri Jan 11, 2013 4:22 pm
Do you not need the crossover section as well?
I rang BTB and I can not remember what the rep said.
Cars
Kedge
Post Fri Jan 11, 2013 4:34 pm
Already have one, they said I wouldn't need a new crossover pipe. The two systems shold be the same length but I've not had them side by side to confirm.
Instagram - Kedge85
blackE30indy
Post Fri Jan 11, 2013 5:11 pm
[quote=] It's a slow burner Indy :-) Looking forward to a ride in yours sometime this year :wink:[/quote]
Ha ha,no problem mate,alot of people are waiting
I'm guessing jims meet is where it's gona happen,
Inless your ever down my end winkeye
blackE30indy
Post Fri Jan 11, 2013 5:12 pm
Your not wrong there Rob :D
Pal318is
Post Fri Jan 11, 2013 5:59 pm
Dave, just read through this thread mate and it's just amazing mate. Hat's off to ya bud :D
The finished car, will just be truly amazing, looking forward to seeing it :cool:
Pal
Image[img]http://Image
Duke137
Post Fri Jan 11, 2013 6:02 pm
Don't compliment him he is a coont :)
Kedge
Post Fri Jan 11, 2013 6:28 pm
Cheers Pal, your iS still going ok?
Duke137 wrote:Don't compliment him he is a coont :)
That's a compliment in itself Fergus!
Instagram - Kedge85
redcar
Post Fri Jan 11, 2013 6:33 pm
Just seen this thread kedge. Looking really really nice :)
Kedge
Post Wed Jan 16, 2013 6:13 pm
Little more progress on the floor today. Walked into find the Fertan had morphed in to a right horrible looking mess;
Followed the instructions and wiped it all down;
Wasn't sure that is was meant to be looking like, spoke to Matt as I'd knew he'd used it and neither of use were sure. I decided to get the heat gun into action to dry off the water and the Fertan just started turning to dust so with a quick wipe with a kitchen towel I was left with this;
It's now had a couple of cost of etch primer and then zinc primer.
Tomorrow I'll be cracking out the seam sealer and then hopefully get a couple of coats of paint down. The heat gun will be working over time again to take the chill out of the surfaces prior to paint and then to get it drying well.
Instagram - Kedge85
redcar
Post Wed Jan 16, 2013 6:23 pm
Shouldn't zinc primer be directly in contact with the bare metal. There's no point to it otherwise.
Kedge
Post Wed Jan 16, 2013 6:29 pm
You only do a light dusting with the etch primer, you're not after a full covering. I just wanted to use the etch to make sure everything on top had a good surface to bite into as I've found some primers need a little help.
Instagram - Kedge85
The_Diddler
Love it up the more door !
Post Wed Jan 16, 2013 8:23 pm
Nice Dave, would love to pop up and have a look see............. :D :D
Kedge
Post Wed Jan 16, 2013 10:03 pm
Cheers Paul, its got nothing on your peadomobile! Welcome anytime I'm not working, don't think I've got your number anymore.
Instagram - Kedge85
Kedge
Post Thu Jan 17, 2013 5:43 pm
Put the heat gun back into overdrive again today. This morning it was the turn of the seam sealer to get smeared into place and then left to set for a few hours after a few minutes under the gun. I took the decision to eep the pedal mount free of it though.
Then this afternoon on went the base coat and then lacquered. Luckily Polaris silver matches cheap wheel silver quite well 8) (pics aren't great as I was running out of light).
Just waiting on some more sound deadening to finish off the floor then just need to run in the stereo wiring before getting the carpet down.
Instagram - Kedge85
Post Thu Jan 17, 2013 6:01 pm
Good work dave - about time you bolted this turd back together :wink:
Jim320i
Post Thu Jan 17, 2013 6:19 pm
Aint jealous too much :(
blackE30indy
Post Thu Jan 17, 2013 6:22 pm
Goin well Dave :)
