Track/fast road 2013 built and tracked
Today ive generally been giving the inside a good clean and sealing up areas that need sealing, ive also removed all the thick foam of the underside of the carpet to shed some wieght as im refitting a carpet in it.
Also ive sorted out the messy leaky sunroof blank
Before
I nipped down the scrappers and chopped a roof of a e36 so id have a neat profiled panel, measured and cut.
Edges filed and corners curved and etch primed
Tiger sealed and riveted into place
Perfect profile
Before
Perfect profile
Hard at work this morning, ive trimmed and fitted a fleece roof lining, alsstarted to reassemble the interior
Foam and sound deadening stripped of the underside of the carpet, so light now
Lining
Opologys for the crap pic quality its making all the black look grey. The dash has been a nightmare to fit, also the cage bolts are to big so ive gotto get some more so I can bolt it all in.
Lining
Rosc0PColtrane
That dash is lovely.
Today ive ground the revets of the sunroof panel and prepped it to give a skim of body filler and refinish.
Ive fked about with a spoiler
Fitted the drop links to the arb
Better pic of the lining I made for the roof
Finished assembling the intake
Prettys :p
Prettys :p
Little update been very busy latley with work ect so have 6 weeks to finish it.... bearing in mind I only get sat/sun to work on it ..
Anyway ive refitted some of the engine up, im hoping to get the innerwings and afew other bits painted + the engine finished tomorrow, if tried fitting the rad with the new electric fan in but its too bulky so im relocting the rad slightly further forward.
Snows let me down this weekend big time plus I wont get on it next weekend this projects not going well and ive majorly regreted starting it
Anyways with a major lack of enthusiasm ive got the interior panels rivited in and made some tidy up panels for the quarter panel this weekend..
What you going to fix your harness to??
