My new 316!
dirtee-herbert
flat caps for the win. they look alot better in my opinion. but either is
dirtee-herbert
Very nice car btw. I love the colour.
Can i ask how you have tinted your mains please?
Hopefully, they're standard French lamps.dirtee-herbert wrote:Can i ask how you have tinted your mains please?
Rich320I
I would think more likely laminex film,Brianmoooore wrote:Hopefully, they're standard French lamps.dirtee-herbert wrote:Can i ask how you have tinted your mains please?
dirtee-herbert
I was just wondering if the OP had used the tinting spray or the film. I have used both and found the spray didn't last very long at all, even after applying propperly with lots of coats to very clean glass and a clear top coat. It only lasted a few months before looking very chipped and nasty.
The film is miles better and has lasted ages in comparison. I was going to advise he used it if he can not get propper french ones.
Propper French lights are the best option.
I'm skint and was undecided so I tried some film on everything. It's easily removed.
*edited for spelling and grammar*
Junglistjed
I used the film mate, mainly because i wanted to make sure i liked it! it works well, just needs to be heated up the right amount. Will ask a few of my mates if they any any flat caps so i can see what they look like before i think about buying!
Car should be going into an old car mechanic for a tune up on monday, will finish off the machine polishing this weekend along with some chrome polishing.. Still not sure if i should keep my interior or now.. drivers seat has a tear so that definitely needs replacing!
joeseth
+1 on flat caps
'89 Lachsilver m42 coupe - Sold
'92 Laguna Green Convertible M50
'97 e36 328i sport - Daily
'89 Alfa Romeo Sprint cloverleaf
kangman
That HD wax i sold you make a difference??
MY FACEBOOK PAGE- CLASSIC STANCE
http://www.facebook.com/pages/Classic-S ... 6444884427
MY FOUR EYED BEAST
MY FOUR EYED BEAST
Junglistjed
Definitely give it a nice shine
any idea what stereo adapter i need guys? my current HU is an ancient pioneer that you just slide in and it turns on.. not wires or anything
Junglistjed
also need a new set of wipers, anything i should buy or just a set of flatblades?
Type of stereo adaptor depends on which model of HU you're fitting!
http://www.e30zone.net/e30zonewiki/index.php/E30_ICE
Adaptors can be bought from Halfords, car audio shops or E-bay, etc.
Junglistjed
No much text in that, all i got from it was that i would need to splice into existing wires in the dash
Junglistjed
Would it be better to get the dent in the drivers wing knocked out, rust removed and resprayed, or buy another wing and just get that resprayed?
If you can, best to stick with the existing wing, as at least you know it fits.
If replacing it, try to get a genuine BMW one, as some aftermarket panels are an atrocious fit and tend to rust quickly.
Junglistjed
Garage have flushed out the piping which was one the the problems and he mentioned something about drilling that he has to finish next monday, its definitely running better though
Presumably, this is the carb issue you're referring to?
Junglistjed
No more cutting out! not sure what he needs to do on monday but all he had to do to the carb was clean it out (like you said ;) ) its actually a really nice drive now.. really enjoying it! my only problem now is the stereo.. it always turns on but its seriously quiet.. not idea whats wrong with it :S just want some music before i upgrade!
hillbilly30
Good news! Them m10's are a really good lump!
Junglistjed
Yeah im surprised to be honest mate, nice and responsive! now just need to get the interior up to scratch and im happy
Good to hear that cleaning out the carb has worked wonders.
I suspect the drilling may either be enlarging something on the carb, or possibly the oil feed pipe to the camshaft - quite a common trick done on M30 engines, as they have a tendency to gum up otherwise.
Junglistjed
Pictures of the wiring incoming guys, removed the cage (not very cleanly! haha) and was welcomed by a fair bit of wiring.. nothing looks spliced into or chopped up though..
adit
you have a PM Jedd
[quote="bss325i"]
First pic appears to be an inline fuse and suppressor choke (in the black box).
Second and fourth pic is the adaptor for your present stero, presumably.
Third and fifth pic appears to show the speaker wiring.
Last pic appears to show a wristwatch and a wrap of ghetto heaven, innit?!
Junglistjed
Any idea what adapter i would need mate? and the wrap is just paper fella!
Find out what make and model stereo you intend to fit, and buy a suitable adaptor from the likes of Halfords, a car audio shop, E-bay, etc.
Junglistjed
Well its an old pioneer HU, but the e30 clip doesn't connect to the loom :/
Just look at the wiring colour code on the existing loom, and use a multimeter to verify such basics as the ignition-switched +12V, permanent +12V, earth, etc. Other connections may be for electric aerial trigger, or amplifier/sub trigger.
Speaker ones are normally fairly obvious, usually dual-tone coloured, e.g. yellow/red and yellow white to left front speaker, blue/red and blue/white to right front speaker, etc.
Speakers are polarised, so try to establish which is earth (they sometimes have a common earth for all four speakers), but it doesn't matter too much if you connect them the wrong way round - it just won't sound as good, if your hearing is acute enough to pick up on such things.
That black connector is the one that fits into the cage that when you slide your removable head unit into the cage, makes contact between the cage and the stereo. It is now obsolete.
You need to get rid of that and go back to the choc block connectors and as above, connect those wires along with the speaker wires from the car to a standard stereo loom from halfords. Then any modern stereo becomes plug and play.
Junglistjed
how much would a set of creme leathers cost? don't need any door cards
Junglistjed
Junglistjed
also, what wiring will i need to buy?
adit
adit wrote:you have a PM Jedd
[quote="bss325i"]
You are probably correct in the identification of both sets of wires, but none looks like OE BMW wiring. If the wire colours have been chosen in accordance with BMW's wiring colour code, then the plain red is unfused 12 volts permanent live, the plain white is unfused 12 volts ignition switched live and brown is earth.
Not recommended using unfused power feeds.
The BMW audio loom supplies both unswitched and switched power feeds, both correctly fused, from the accessories socket behind the glovebox.
DaveyB
im running 9j bobets with flat capsJunglistjed wrote:Just curious, do people think the wheels will look better with flat caps? like the pic below..
best wheels by far
get flat caps
Wanted Nothing atm
