325i touring PYF, a new little pic i found!
Theo
Post Wed Apr 16, 2008 11:47 pm
A spare gear linkage is now in my 'Ring Spares' box! 250 miles in 4th is not something I want to do again :o:
oguz327
Captain Armco
Captain Armco
Post Thu Apr 17, 2008 1:21 am
Simon, ill pop up sunday to help out and cause trouble :D
Post Thu Apr 17, 2008 2:05 pm
iS it true this engines demise was caused by a 60mm slammed council chariot hitting a speedbump or is that just an educated guess ? :o
Post Thu Apr 17, 2008 6:00 pm
pacerpete wrote:iS it true this engines demise was caused by a 60mm slammed council chariot hitting a speedbump or is that just an educated guess ? :o
maybe! it's probably 80% the reason but i won't know until i strip it. Thing is the sump is intact and it isn't leaking any oil
bmwe30mtech
Post Thu Apr 17, 2008 7:59 pm
Glad you seem to have taken this bit of news quite well considering!
I know its a workhorse but i really like this car. Just promise me you wont be using the alpina interior as a builders caff also!
Post Thu Apr 17, 2008 8:31 pm
alpina isn't and won't be for work use, just a weekend/evening toy
I towed it back last night and the engine is ready to pull out on the weekend everything is diconnected and and un plugged.
Drained the oil and it was full of swarf almost 8O some quite large shiney "bits" floating about in there, poor thing
oguz327
Captain Armco
Captain Armco
Post Thu Apr 17, 2008 8:53 pm
At least it didnt shit it self at the ring!
Jesus325iTouring
Frog freak !
Frog freak !
Post Thu Apr 17, 2008 10:10 pm
Well Si,you beat me in the end,my engine had enough circa 233,000 miles,it was still running mind,I just could no longer warrant putting a litre of oil a day in it!
I love your interior,reminds me of someone elses winkeye winkeye
Karan
Post Sat Apr 19, 2008 3:59 pm
shit sorry to hear this give us a shout if you want a hand swapping dude.... sure it wont take long :cool:
Karan
fuzzy
He who sleeps with "Gingers"
Post Sat Apr 19, 2008 4:19 pm
oguz327 wrote:At least it didnt shit it self at the ring!
that would be a nightmare scenario. hundreds of miles from home in a foreign country.
Post Sun Apr 20, 2008 11:04 pm
Got the engine out today :? had a bit of a poke around once it was out but i'll know a bit more tomorrow
Chav i know before anyone says!
It's out!
fubared clutch
Do i clean in here this week?!
So hopefully i'll have my lightened flywheel of Temple30 and i can get my replacement engine in and fitted with a new clutch and some other bits and see how long the next engine lasts! lol
oguz327
Captain Armco
Captain Armco
Post Sun Apr 20, 2008 11:12 pm
I would give the engine bay a good clean Simon, will make it a nicer place to work and its easy with the engine out init!
Dont stop there though, if you open the door you will find the driving control area which could also do with a damn good clean and general cess removal :D
cue mattg dissing the state of my van winkeye
Post Sun Apr 20, 2008 11:13 pm
but it's just a milege whore! i might* do that
Post Sun Apr 20, 2008 11:22 pm
Do it you scumbag!
Post Mon Apr 21, 2008 6:41 am
Looks like you had a succesful day Si. At least the wather held out. Keep the photos coming. When you pulling the Auto lump out?
Karan
Post Mon Apr 21, 2008 10:35 am
good stuff!..yeh may aswell giove bay a clean, makes it a much nicer place to work
andyp
True Old Skooler
Post Mon Apr 21, 2008 10:48 am
only just seen this post, only read this page so far, cant believe you killed a perfect good engine.
Post Mon Apr 21, 2008 4:59 pm
i didnt kill it. The sump was intact as i said. I drained 4 litres of oil out. Clearly a pump issue, it looks like now. I'm about to go out and strip it right down. My only concern now is to see whats worn out, mainly on the top end. Cam lobes look good but i want to get the cam out to check the main ends and pray that a pukka head isnt scrap
Post Mon Apr 21, 2008 5:07 pm
As you say Si. at 230k the pumps probably f*cked. Did you manage to get a new one for the auto lump? Money well spent I reckon as their similar mileage.
Post Mon Apr 21, 2008 5:18 pm
i have a new pump yes and soon a light flywheel, should spice up this standard lump a touch!
Post Mon Apr 21, 2008 7:01 pm
Simon13 wrote:
Just spotted this. Look like your about to start crying in this shot :cry: :cry: :cry: :cry: :cry:
Jesus325iTouring
Frog freak !
Frog freak !
Post Mon Apr 21, 2008 8:40 pm
Proper heroness going on here Si :cool: Great to see another E30 being saved rather than sent to China to made into Coke cans and airplanes,why let major engine failure be an issue 8)
PS Good to see you've got windscreen wipers to,do they actually work or just for show?! :wink:
Post Mon Apr 21, 2008 11:21 pm
Stripped her down tonight and found the "problem" lol
Shells look like they were getting hot! would of seized quickly i recon
Pistons coming out usual wear on the thrust side, bores look pukka with honing marks clearly seen down all of the bores but nothing obviously wrong yet........
Hmmm bits of red plastic in the sump
Time to look at the oil pump
Ouch that'll be why the oil light came on! The bloody spindle had snapped but why?
broken spindle next to a good one
Also i couldn't spin the pump gears round by hand, so i took that apart
Pictures are sh!te but basically the gears were jammed by a small piece of metal. You can see in the bottom pic where theres a big groove in the casing and then the pump or spindle had had enough. It nearly worked it's way right round though. Who knows what would of happened if it had been passed else where through the lump. What gets me is how did it get through the filter? i doesn't really look small enough
Also it doesn't prove to me that wacking the sump on a speed hump caused this to happen either and it could of been a coincidence?
Top end was mint and had no wear on the cam lobes or rockers. Light scores on the main ends of the cam but don't they all? So overall i'm pleased that the engine looked to be in good health, and lots of parts can still be re used. So i think as i quite like this engine it shall have to be rebuilt into a 2.7 of some sort.
oguz327
Captain Armco
Captain Armco
Post Tue Apr 22, 2008 12:03 am
Interesting stuff Simon.
Looks like an oil pump change would be wise at 200k or sooner for anyone else reading this.
Good to hear the cam and head are ok to re-use, any more thoughts on what spec 2.7 your going for?
I take it the cam and alpina pistons? :D
Post Tue Apr 22, 2008 12:09 am
Nice one, at least the top end parts are ok. :D
stonesie
Post Tue Apr 22, 2008 12:44 am
Well the filter is after the pump, you need to see if the strainer has any holes in gauze before you re-use that, to be honest that piece of metal could have been sat in the sump in a quiet corner out of the main flow of oil for weeks, months eaven years. Then it got disturbed and somhow got past the strainer, only the tight tolerances of the pump gears stopped it makeing its way into the bowells of the engine and saved your top end.
Bewdley320T
Post Tue Apr 22, 2008 1:11 am
[quote]Hmmm bits of red plastic in the sump
Did I miss it or did you find out what the red plastic bits were??
Post Tue Apr 22, 2008 6:54 am
Si you lucky git! one saved top end but I reckon only by your fast reaction to shut it down.
Excellent write up to mate.
mattG
Post Tue Apr 22, 2008 10:02 am
oguz327 wrote:I would give the engine bay a good clean Simon, will make it a nicer place to work and its easy with the engine out init!
the stink is beyond words :puke:
Si did you get finished on Sunday or did that S50 turd distract you :snigger:
(\__/)
(='.'=)Simon13 wrote:
323's were dangerous this will un drivable in the wet!
MattG - hedgefinding specialist
E21 turbo
Can be your new sig matt!
Post Tue Apr 22, 2008 5:35 pm
i won't be re using the oil pump! Thing is i cleaned out the sump when i changed the gasket last year.
The red plastic bits are off the broken spindle, Matt i only got the old engine out on sunday i'm getting the new one in this weekend i hope!
d6dph
Post Tue Apr 22, 2008 7:05 pm
Simon13 wrote:
"Missing member of Goldie looking chain found"
Guns don't kill people, M20's do! :D
gooner1
Out humping Reindeer
Post Tue Apr 22, 2008 7:13 pm
:rofl:
Good write up Simon.
bobafett
Post Tue Apr 22, 2008 7:50 pm
Now that's a write-up ! Great work mate!!!!
What ?! Drive straight officer......It's an E30 !
It's the Ultimate Drifting Machine.
Karan
Post Wed Apr 23, 2008 11:20 am
something u left in there Si last time u had the sump off??? :mad:
good to hear the top end is ok, she was a screamer!
tomtomiS
Post Thu Apr 24, 2008 11:52 pm
you will all be pleased to know that a healthy dose of tfr has been let loose on the engine bay, it kinda looks reasonable in there now!!
