red wagon project back to m42 plan
Fri Jun 15, 2018 6:29 pm
lots of cleaning later .....
and then for good measure some paint prep .... FML ! :cry:
Jesus325iTouring
Frog freak !
Frog freak !
Fri Jun 15, 2018 6:37 pm
Down South we would have undone those manifold studs by fingers, making a meal of it Micky :wink:
Joking aside, what is the reason for fitting the E36 M42 and not something 6 cylinder related?
Fri Jun 15, 2018 6:58 pm
Jesus325iTouring wrote:Down South we would have undone those manifold studs by fingers, making a meal of it Micky :wink:
i have two m42 engines here and one has only done 52k miles
that's good enough reason for me .
Jesus325iTouring
Frog freak !
Frog freak !
Fri Jun 15, 2018 7:46 pm
Fair enough mate, I was just curious. Is the a build to sell then? I guess you have your stroker for the toy.
Fri Jun 15, 2018 8:56 pm
Jesus325iTouring wrote:Fair enough mate, I was just curious. Is the a build to sell then? I guess you have your stroker for the toy.
that was the original plan ... no wait that was to fragg it , then it was fix it up and sell it ... now it's had loads of love and attention i might keep it .... i want to at least put a few miles on the finished job and dial it in as there is always fine tuning .
instead of selling i might swap for something boosted to blow up haha .
or boost this m42 ...
Thu Jun 21, 2018 6:34 pm
had a few hours on the engine today and sorted out the cop conversion after the plate turned up with no fixings and doesn't sit flush so i had to splash out £3 on some diy fixings from the nut and bolt shop just up the road 8) got all the allen key head bolts to fix the coils to the plate as well so that's one job out of the way .... mocked it up on the e36 rocker cover , the e30 cover is painted now .
£3 the cheapest parts i've ever bought :D
my plan :?
i'm a f00kin engineer me like :D
happy with that i painted the e30 rocker cover i had prepared earlier .....
the inlet is painted and finished , rocker cover needs the fins sanded back to alloy so no pics until those are both finished ...
moved on to the gearbox that's now nice and shiny ready to fit as soon as the donk comes off the engine stand ....
it might even move under it's own steam this year
steve_k
Thu Jun 21, 2018 6:48 pm
well safe o say you can call yourself a true e30 owner after "fixing" a problem so quickly & cheaply :D
Fri Jun 22, 2018 2:52 pm
Proper engineers us like !!!"
Fri Jun 29, 2018 6:43 pm
turns out i needed a couple of bits still like an m42 specific p/s pulley wheel and a rear gear selector bush .
i bought a good used correct pulley wheel which arrived yesterday along with the rear selector bushing. i
had to buy a poly one from the states which wouldn't fit over the selector barbs at rear of shaft and even if i ground the barbs off it looks to be about 1mm to big and will have a bit of slop .
i had a look through a couple of tubs full of " i might need this one day parts " and hit the jackpot :D
these little f00kas are about £55 from BMW ! just needs a clean up .
i fitted the bungs i'd ordered for the throttle body delete one for the plastic pipe and one for the head stub , nice and tidy job better than a cut hose with a bolt shoved in lol .....
got the inlet manifold and rocker cover fitted , next job to plumb in the oil breather pipe to the throttle body stub and the icv to the intake boot , no problems and done a nice tidy job .
my spigot bearing arrived so got the engine off the stand , fitted the bearing ...
had this as new sachs clutch on the shelf ready to go
now it's all bolted together and ready to fit .... i hope the e36 m42 engine mounts work after a slight modification .
i got a bit excited and fitted the fogs to the freshly painted valance
happy with me bit progress so far :D
TPS
Sat Jun 30, 2018 7:44 am
Looking Good Mick
Sat Jun 30, 2018 2:01 pm
Looking great Mick !!
When you said E36 M42 could you have used the M44 ?
Sat Jun 30, 2018 3:59 pm
martauto wrote:Looking great Mick !!
not with the e30 loom and ecu i don't think .... m44 isn't a forged crank either .
cheffy
Mon Jul 02, 2018 9:33 pm
Looking very good Mick, that engine looks stunning, better than new / when it left the factory
robbo86
Tue Jul 03, 2018 2:52 am
Damnit. I’ve just read through this entire thread. Been off the Zone for a little while now. Making my miss my IS converted E30.
terryjippo
Tue Jul 03, 2018 10:26 am
The M42 in an E30 is a wonderful thing, perfectly balanced for pressing on, especially around the twisty stuff.
Lovely progress Mick, how much of hassle was it to make the wiring loom fit?
Tue Jul 03, 2018 6:24 pm
was a straight fit i just threw the e36 knock sensors in the bin as no plugs for them but had to change the alternator and it's mount , the p/s pump and pulley , the trigger wheel and pulleys , and the water pump pulley .... all pulleys need to be from a 318is e30 . m40 won't fit .
well after paint match attempt no 2 ..... i think that's about as close as i'm gonna get , and not too shabby :D
and the e36 engine mounts worked a treat with the locating tabs ground off ...... finaly it's in ! :P
coasting along happily until the wrong oil filter turns up ! :roll:
just need to remove the diff from a 318i m10 turd i've got that should have a 3.91 small case fitted ... i'm not gonna fit a 4.10 as i want some slightly longer legs in 5th gear .
well there is bit more left to do than just fit the diff but it's closer to being finished .
terryjippo
Wed Jul 04, 2018 1:46 pm
Thanks for that re wiring, good to know.
Take it you also reused E30 ecu also, or was that from the M42 E36?
Wed Jul 04, 2018 6:05 pm
e30 ecu .... i had a full e30 m42 with unknown miles and put everything needed from that onto the low miler e36 m42 i bought from Andyboy on here , [ Andrew Everette ].
terryjippo
Thu Jul 05, 2018 9:34 am
Ok makes sense, so presume the wiring loom came from that also?
I've got an E36 M42 here from a rusty SA 318is, that I'm going to use for a E30 transplant, once I find a suitably solid car to stick it in...
Fri Jul 13, 2018 5:11 pm
so today this happened >>>
[youtube][/youtube]
i'll fit the diff put a prop on, exhaust and bleed clutch next week , well basically get it all finished bar the paint on wings/bonnet .
happy it starts though now i can move on :D
Fri Jul 13, 2018 5:24 pm
Nice one Mick, always cool when she "lives" again.
Thu Jul 26, 2018 8:43 pm
i found a really nice passenger seat in my loft so converted it the the drivers seat by swapping the seat runners and hardware over from a drivers seat .
gave it a good clean and.......... well happy with that 8)
Tue Aug 07, 2018 7:17 pm
all the mechanical work appears to be done now apart from adjust the coil overs up to a sensible ride height , i had to take all the inlet manifold back off and change the temp sensor as i'd left the e36 one in which has two pins and swap it for an e30 one. now my temp gauge works :mad:
also had to take the zaust manifold off and have a weld done as the usual m42 blow from cylinder 1 was in effect but that's all sorted after fiddly shit job getting at all the bolts , glad it's a 4-pot winkeye .
really close for an mot now and a shakedown and then probably some mechanical tweeks if needed .
Wed Aug 08, 2018 12:25 pm
Looks pretty cool Mick. Is this a keeper then?
aimlessrock
Wed Aug 08, 2018 12:28 pm
looking good mick.
E30 320i Convertible (1989)
190 Mercedes (1988)
Wed Aug 08, 2018 6:15 pm
martauto wrote:Looks pretty cool Mick. Is this a keeper then?
not sure what the plan is yet , i don't need to sell it and i quite like it lol .
aimlessrock wrote:looking good mick.
cheers 8)
got a few bits nailed back on today and the paint match is pretty good so now i can get this finished .
Black_Op_88
Sat Aug 18, 2018 9:38 am
I love these build threads. Keep the photos coming. I'm watching even if I'm not posting :D
Sat Aug 18, 2018 5:13 pm
Black_Op_88 wrote:I love these build threads. Keep the photos coming. I'm watching even if I'm not posting :D
cheers , i should have an update end of next week :D
Tue Aug 21, 2018 11:35 pm
some lucky new owner just paid a deposit and secured it :D
damn :D it's the 2nd longest car i've owned , only drove it home 2yrs ago then round the block last week . i'm booking it's mot 25 mile away though haha ... i will get to drive it :D
Thu Aug 30, 2018 6:46 pm
well the saga continues , the buyer pulled out yesterday as he's found another car he has to buy [ originally looking for a 2dr ] , no big deal to me although i am now £200 better off.
Aaand another buyer wanting to view/purchase it mid sept .
the final bits of work on the car are planned for tomorrow, the bonnet is now painted so the wings and bonnet are being fitted then flattened and polished then it's ready for mot :D
hopefully a few pics of a complete car tomorrow .
Thu Aug 30, 2018 6:54 pm
Just dont know what people require these days ?
A few beer tokens why i man ?
billyfrost
Thu Aug 30, 2018 7:03 pm
Geet darzer Mick
Thu Aug 30, 2018 7:11 pm
billyfrost wrote:Geet darzer Mick
cheers 8)
martauto wrote:Just dont know what people require these days ?
A few beer tokens why i man ?>>> way aye man <<<
well a deposit on a car is none refundable where i come from,
he seemed well happy about the car and was keen to collect it with it's 12 month mot , ah well he must be caked :mad:
billyfrost
Thu Aug 30, 2018 7:46 pm
I once sold a Lotus Esprit on ebay, chap turned up and gave me £300 * not to buy it *
Thu Aug 30, 2018 10:54 pm
billyfrost wrote:I once sold a Lotus Esprit on ebay, chap turned up and gave me £300 * not to buy it *
golden handshake :D
