Kailine full resto
habana
Thu Mar 09, 2023 4:51 pm
Hi
As in another topic (2012) all my previous messages are gone, I will start here with a new topic.
Currently I have this car in my possession for about 17 years.
During these years it underwent almost a complete restoration which I will update here bit by bit.
This sedan started life in 1988 and has a body kit of a German tuner (back in the days from the eighties) called Kailine.
On this car the kit includes:
- Bilstein suspension
- Kailine steering wheel
- Kailine wheels
- Kailine front bumper, side skirts, rear bumper and bootlid spoiler.
Other Kailine options possible back in the day were other grilles and even a turbo kit, but this car didn't came along with it. Also E34 and E32 had similar kits.
habana
Thu Mar 09, 2023 4:53 pm
The car as I bought it 17 years ago.
habana
Thu Mar 09, 2023 4:55 pm
Current state
habana
Thu Mar 09, 2023 4:58 pm
Engine bay
Interior, analog oil pressure gauge will move as it will be visible on the can display
habana
Thu Mar 09, 2023 5:02 pm
underbody redone, complete suspension overhaul incl all bushings, subframes, axle shafts, driveshaft, new 3.91 OS Giken Superlock LSD.
I must say, the car is a joy to drive. The sound of the inlet combined with the exhaust note gives goosebumps, car is always asking for more!​
Some years ago after receiving new paint and some grille work. However, as the car is used for roadtrips, mountain driving and an occasional Nurburging Nordschleife lap, it's a challenge to keep the car in this state. The fact that I enjoy driving above cleaning also doesn't help :)
Thu Mar 09, 2023 5:19 pm
Hell thats cooooooooooooooooooooool.
It`s superb now with plenty of attitude so back in the day it must have been "Radical"to say the least
I must admit I have never heard of this tuning company ,but they got this one right fist time.
:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
steve_k
Fri Mar 10, 2023 8:48 am
now i'm not normally a four door fan (don't know why :oops: ) but that looks really good,
whats the full spec on the engine? any sound clips??
tha881
Sat Mar 11, 2023 2:32 pm
That's a lovely car, some very nice parts there that finish it off perfectly
:clap:
HartgeH27
Sun Mar 12, 2023 6:54 pm
I too like Steve have never heard of Kailine but they have done a great job with their styling. I can sense the hard work and compassion given to this car. Bravo. I you running RAMA's on there ? Beautiful car!
Muzz2676
Sat Mar 25, 2023 7:39 am
Amazing, that looks lovely. There's hope for my more door yet! As mentioned previously, interested to hear spec of engine and which ITB's you went for.
habana
Thu Apr 13, 2023 11:05 am
After break-in it was time for dyno day!
Lots of torque as foreseen, however top end flattens a bit faster than thought, apparently due to airflow.
Could be the size of ITB's which is on the small side, or the valves, or the head.. As it is a streetcar, I am not planning to change the setup as I don't want to lose torque in the quest for finding more hp in the upper range.
Anyhow the car is a beast :mad:
Pushed it once towards 7800 rpm, however limiter is set at a save 7000 rpm.
HartgeH27
Thu Apr 13, 2023 11:29 am
Nice graph, nice diagonal curve. Similar figures to my n/a 3.1 and 280bhp and 325 nm torque. I am running on Rama RHD ITBs 42mm. What diameter you currently running? Keep up the good progress !
HartgeH27
Thu Apr 13, 2023 11:31 am
Oh and after chewing 2 clutches I have fitted a kevlar one now, manages the torque fine. The other two snapped the bands on both even after only 50 miles or so.
habana
Thu Apr 13, 2023 11:46 am
I am not sure what is choking airflow.
Running 40mm ones from RHD, but I am also running Schrick valves with oem diameter, however valve stem towards valve head diameter is significantly smaller than oem valves, which in result should flow more. Head is also ported and polished (again no supercrazy things as the car remains a streetcar where durability for me was important).
Cam should peak at 7000 rpm.
habana
Thu Apr 13, 2023 11:47 am
Thanks, appreciated, I was already thinking at future problems so we placed one from Sachs which should withstand 350nm.
HartgeH27
Thu Apr 13, 2023 9:41 pm
[img]C:\Users\Owner\Documents\hartge build sheet 1.jpg[/img]
HartgeH27
Thu Apr 13, 2023 9:44 pm
Am having snags with pics tonight on here. What is your fb please, mine is Iain P Hamilton
habana
Tue Apr 25, 2023 10:46 am
Mine is Gregory Blondeel
What do you have as cooling setup? Which water temp are you running?
I switched to a thermastat that opens at 75° or 80°c I believe, placed a new oem radiator (big tropical version), deleted the visco fan and placed an electric one in front of the radiator.
While driving temp is fine, however when idling a bit to long temp rises to 95°c and above. Should find a solution for this as it's not even full summer weather.
