pimp my headlining
Cloggy Saint
Sat Apr 26, 2008 8:22 pm
Today I finally got around to finishing my touring's headlining. On the whole I'm pretty pleased with the way it turned out, there're a few wrinkles here and there but nothing too obvious. I just hope the glue withstands the summer heat.
doctorspike
Sat Apr 26, 2008 8:26 pm
want to do mine man :cry:
doc
march109
Sat Apr 26, 2008 8:39 pm
Starch it too before you put it back. the starch keeps it stiff hich in turn stops it stressing the join on the glue
Cloggy Saint
Sat Apr 26, 2008 8:44 pm
Really? Afraid I don't know too much about starch, is it liquid :o: ?
mattG
Sat Apr 26, 2008 8:55 pm
Looks good from here, one of the jobs on my todo list as I've currently got the CSL look :(
March will the starch affect the nap & could you still brush it after it is starched?
(\__/)
(='.'=)Simon13 wrote:
323's were dangerous this will un drivable in the wet!
MattG - hedgefinding specialist
E21 turbo
Can be your new sig matt!
dips346
London Meets Main Man
Sat Apr 26, 2008 9:59 pm
LOOKS ACE ,told you its not hard to do :D
Cloggy Saint
Sat Apr 26, 2008 10:50 pm
Cheers Dips, and thanks for the advice. Like I said, I'm not convinced it's going to hold, so if it comes down I'll try it with a lighter, thinner material.
toby
Sun Apr 27, 2008 10:36 am
Nice job. I bet that will be fine, the heavier material notwithstanding.
I may do that to mine when it sags back down again. Thanks for the inspiration.
barryj
Sun Apr 27, 2008 11:03 am
Is it alacantara?
Cloggy Saint
Sun Apr 27, 2008 11:08 am
It's fake suede, but looks the part.
citizensnips
Sun Apr 27, 2008 11:50 am
does the headlining mount to some sort of board that attaches to the roof, thats what it looks like from the picture or is it like the ones with the thin metal strips going across the roof?
Cloggy Saint
Sun Apr 27, 2008 5:57 pm
The original set up is a rigid fibreglass board, then a foam layer and then the outer material.
oze30
Sun Apr 27, 2008 6:57 pm
Mine stuck, but I rushed mine and faffed about, and it needs to be re stuck or hair dyed back up.
Not a difficult job, just fiddly.
dips346
Sun Apr 27, 2008 7:08 pm
mine is fine but i did use the thinner verson
oze30
Sun Apr 27, 2008 11:23 pm
Depends on the glue you use as well.
bmwscorpion
Wed Apr 30, 2008 2:45 pm
On this topic. how easy does the roof lining come out of a touring. ? do you have to remove the rear glass??
any help would be appreciated. :D
Cloggy Saint
Wed Apr 30, 2008 2:53 pm
No glass removal necessary! Remove grab handles, check control, sun visors, interior lights etc. Pull the rubber door seals down. There are four clips at the rear, one either side of the tailgate hinges. Once these are released it's just a case of giving the headlining a tug backwards to free it from the four points holding it up in the middle. All will become clear once it's out!
bmwscorpion
Wed Apr 30, 2008 2:55 pm
Thats excellent thank you , it was one job I really didnt want to do. but sounds easy enough..
Cheers.. :D
Wed Apr 30, 2008 9:39 pm
good work Ed, I'm waaay too lazy for recovering the lining, a can of spray paint would be my chosen method :o
cros
Thu May 01, 2008 1:56 pm
Out of interest, what are the extra holes in your headlining for?
(On the left and right over centre of the boot section)
dips346
Thu May 01, 2008 2:17 pm
cros wrote:Out of interest, what are the extra holes in your headlining for?
its for the dog guard clips for the rear blind
oze30
Thu May 01, 2008 11:50 pm
Just realised he had the easy option.
NO SUNROOF! :x
Cloggy Saint
Fri May 02, 2008 7:16 am
It helps, in more ways than one!
