320 refuses to start on COLD?! sighhh
wks79
Mon Feb 18, 2008 3:41 pm
another problem has raised its ugly head on my e30 .
apart from the low idle at bout 650-700rpm with the AC on.
its getting more difficult to start the engine when cold .
now sometimes the car starts only after 3-5mins of leaving it on key position 2. sometimes i'd have to give the gas pedal a few blips before i could start it .
its not consistent.
is it normal for an e30 to start without keep the foot on the gas pedal?
should it just starts without the gas being pressed .
any advice would be appreciated,
before the problem becomes worse.
cheers :cry:
blitz877
AKA ajm-e30
Mon Feb 18, 2008 3:55 pm
dont press the throttle pedal when starting as it will flood the cylinders
wks79
Mon Feb 18, 2008 3:56 pm
thats the only way it'll start sometimes :(
**BANNED**
Mon Feb 18, 2008 4:09 pm
Sounds to me as if the ECU thinks the engine is warm...blue temp sensor not playing?...
Youth is wasted on the young.
Stan0870
Mon Feb 18, 2008 7:39 pm
Hello mate,it sounds like the enriching devise is failing.(choke in old money),again as daimlerman suggests blue temp sensor.. as for the low idle when the AC is on, that sounds like a charging problem. have you checked the belts?
wks79
Tue Feb 19, 2008 4:27 am
what belt are we talking bout Stan0870?
Stan0870
Thu Feb 21, 2008 10:57 pm
if its a charging problem! altenator belt, are you getting a similar problem with anything else thats applying load to the circuit? ie headlamps.
wks79
Fri Feb 22, 2008 11:27 pm
problem of starting the car seems to have went away for now ..
hopefully stay away for asome time to come .
thanks all 4 the advice
Fri Feb 22, 2008 11:31 pm
Check out the plug and socket for the injector loom, fixed to the metalwork under the middle of the inlet manifold.
Not just the pins and sockets, but for corroded wires under the lower rubber boot as well.
