Alpina Throttle Body
davrosbeemer
Post Mon May 23, 2005 5:54 pm
Is the throttle body fitted to the Alpina C2 the same as a 325 one? Or were these changed along with the engine at time of conversion?
Any ideas?
rickk
Post Tue May 24, 2005 10:14 am
Well, at least they've seemed to have supplied one for the C2 2.5, check out the (german) catalog:
http://www.behindmatrix.com/e30/fotost/f01118/tkc1.pdf
M5pilot
Post Tue May 24, 2005 11:50 am
Exactly the same.
davrosbeemer
Post Tue May 24, 2005 8:56 pm
Thanks for the replies. My German isn't so good but thats quite a good PDF.
I have a throttle body on the way that was off an Alpina :D . I guessed it was probably the same as a 325 but heh ho, I can tell my mates its Alpina spec! LOL
davrosbeemer
Post Wed May 25, 2005 7:52 pm
I received this today and after looking at it and flicking through some threads on here I reckon I should drill out an extra hole for my second vacuum pipe. There is already a hole for it but it does not go right through to the internal chamber.
Any thoughts?
alpina527
Post Thu Jun 02, 2005 11:32 pm
I can supply you with a bog bore version at Ԛ£120 exchange. mail alpina527@aol.com
