cigarette lighter socket
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sun May 22, 2005 10:12 pm
I have ~12v at the wires but can't draw and real current from it.
have tried two actual sockets still no joy, I'm pretty sure the problem isn't the socket. obviously it's not the fuse as there's voltage there.
Any ideas?
Post Sun May 22, 2005 10:49 pm
How did you measure the 12V?
If it was just with a meter, then the results are virtually meaningless, since a series resistance of several thousand ohms would have no significant effect on the measured voltage. A far better tool to use for electrical checking is a 12V 10W lamp attached to a couple of short leads.
The problem could very well be the fuse, No 28.
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Mon May 23, 2005 12:33 am
once again brian, thankyou :) I'll check the fuse.
