Electric fan conversion (M20 engine 325i)
Finny
Post Thu May 19, 2005 3:50 pm
First of all, is this worth doing?
If so does anyone know of any company which sells conversion kits, obviously i could use pretty much any fan but im thinking of the switch components.
Has anyone attempted such a conversion?
Finny
BrAdZ
Post Thu May 19, 2005 5:46 pm
i know kenlowe do kits to suit any car, had one fitted to my capri, and they also do a t peice that goes on one of your hozes to determin the temp for the fan to cut in
Hope this helps
Karan
Post Thu May 19, 2005 5:47 pm
yeh its worth it...... the viscous is unreliable crap....
Post Thu May 19, 2005 9:14 pm
The electric fan from a E34 5 series and 7 series with aircon fits in front of the E30 radiator perfectly.
There is a untapped boss on the side of an E30 radiator, but if you have had a replacement radiator, then you will probably find a blanking plug where the 5/7 series thermo switch will fit.
The E30 fusebox has two unused positions for relays (high speed and low speed), and a place for a fuse. You just have to make up a small loom.
Most of us who have fitted M50 engines to our cars have fitted electric fans, as there is no room for the standard viscous fans.
