Getting bottom pulley off?!
Adammcf
Post Sun May 15, 2005 7:42 pm
Im having great fun removing the head on the car. First the fan wouldnt come off and now I cant seem to get the bottom pulley off to get at the timing belt.
Should it just come off by pulling on it?
cabrio327i
Post Sun May 15, 2005 7:50 pm
Yeah will come off has long as you have all the bolts out, give it a tap with a copper malet or something that wont damage it, Dave
Widge
Post Sun May 15, 2005 7:52 pm
Whack it with the bigges hammer you have got, try tapping the shaft in the middle to get the vibrations to release it. It will come off just persevere :D
Adammcf
Post Mon May 16, 2005 9:59 pm
Came off nice and easy which surprised me. It seems alot tighter yesterday.
Couple of little taps with mr hammer and it was boogytime!
Davenotouring
Post Mon May 16, 2005 10:18 pm
Do you not have to undo the massive bolt in the centre? :)
BMW 328i Cab - Daily Slag
Widge
Post Mon May 16, 2005 10:21 pm
No you ninny, there's about 6 11 mm (I think) bolts inside the dish of the pulley. A long reach socket really helps.
Davenotouring
Post Mon May 16, 2005 10:22 pm
:cry:
That's not very nice. :(
:wink: :)
What is that big one holding on then?
Widge
Post Mon May 16, 2005 10:28 pm
Where I come from Ninny is a term of endearment :wink:
No offence :D
Dunno as far as I know it's bolted in to the front of the crank!
I'll tell you in 2 months when I've stripped my 2.5 donor engine :twisted:
Davenotouring
Post Mon May 16, 2005 10:43 pm
So this bolt doesn't come off with the pulley then?
If that is the case, then I understand! :?
Widge
Post Mon May 16, 2005 10:52 pm
No it stays ther and you use it with a 21mm spanner to turn the crank to get the timing marks lined up. If your thinking about doing the timing belt drop me a line cos I did 3 over easter and know wher it can go wrong :oops:
Davenotouring
Post Mon May 16, 2005 10:54 pm
Will be trying to do the timing when I put the head back on and so on.
Thanks for the offer, I will no doubt be taking that up!
LOOPYLEE1965
Post Mon May 16, 2005 10:59 pm
if youve got the right tackle you dont need a hammer i would have used a 3 legged puller at the end of each leg a small dog clips ontothe pulley you put a 13mm socket on the central bolt and wind it in with a ratchet and it just pops the pulley off no sweating or hammer swinging (no chance of breaking anything else either bin there and done that :lol: ) think mine only cost about Ԛ£10 from local motorfactors
Widge
Post Mon May 16, 2005 11:48 pm
Wouldn't fit the front chassis member is in the way.
LOOPYLEE1965
Post Tue May 17, 2005 12:15 am
not done this job on me e30 yet mate but tried it on a mg montego turb a nd cost me a new rad as well :x :x :x
Adammcf
Post Tue May 17, 2005 8:58 am
When its off it looks like this:
