Tricky to select first gear
daveyboy20
Sat Dec 08, 2007 3:37 pm
As said, from a standstill i have to push pretty hard to get it in to first, if i select another gear first it seems easier to then pop it in first. Its fine driving around and with the car slightly rollin its easier to pop it into first too but from a dead standstill its quite hard. Any ideas? I occasionally feel the clutch pedal 'undulating' (is that the right word...) under my foot when driving, a kind of very light hardly detectable throb occasionally, dont know if this is related? Cheers, Dave
daveyboy20
Sat Dec 08, 2007 6:45 pm
Anyone have any ideas?
HairyScreech
Sat Dec 08, 2007 7:19 pm
syncromesh on 1st or your clutch plates are off centre/warped and dragging.
rab-doo
Sat Dec 08, 2007 7:31 pm
Same thing on mine - plus a little crunch on second when cold from time to time.
Doe this basically mean thet the Gearbox is scrap / needs reconned?
march109
Sat Dec 08, 2007 7:34 pm
rab-doo wrote:Same thing on mine - plus a little crunch on second when cold from time to time.
Yours deffo sounds synchro related. tbh secondhand gearbox is cheaper than a recon at the moment.
Heyho
Sat Dec 08, 2007 7:38 pm
I would say that the symptoms you are describing are almost certainly due to dry and probably rusty splines on the input shaft/clutch centre plate.
By the time you have the box out to clean and grease it, you may as well chuck a clutch in there. BMW manual boxes are very strong, and it's rare to see one broken, or even a synchro worn out.
rab-doo
Sat Dec 08, 2007 8:13 pm
I'm planning a new clutch but I've kinda got a list as long as my arm to deal with first - reckon i'll drive on 'til something goes bang one day then sort it. That's what RAC cover's for!
In the mean time I'll change the 'box oil and cross my fingers :wink:
Sat Dec 08, 2007 10:01 pm
rab-doo wrote:!In the mean time I'll change the 'box oil and cross my fingers :wink:
Change it for Dextron II ATF fluid, and see if that improves things.
rab-doo
Sat Dec 08, 2007 11:15 pm
I bought 5L of GL-4 80-90 Hypoid oil for the diff cos I read somewhere that this would be fine for the box too- even though Hypoid was not called for.
I also have ATF Type D, which is recommended by Valvoline for E36 318is manual (no E30 318is on their adviser). Is there much difference between Type D and Dextron II?
I'd like to use what I've got if possible.
Sat Dec 08, 2007 11:30 pm
rab-doo wrote:I also have ATF Type D, which is recommended by Valvoline for E36 318is manual (no E30 318is on their adviser). Is there much difference between Type D and Dextron II?
Quick google suggests that it's OK.
rab-doo
Sat Dec 08, 2007 11:48 pm
Cheers Brianmooore.
Apologies to Daveyboy for hijacking your thread.
mrLEE30
Sun Dec 09, 2007 4:56 am
could also be the shift lever bushings
daveyboy20
Sun Dec 09, 2007 9:57 am
No worries! So as far as i can tell the gearbox is ok, could be slightly worn clutch and it may improve with a change of gearbox oil?
cypriot_boy_2k7
Sun Dec 09, 2007 1:02 pm
mine crunches, was told it was syncros, very bad in cold weather, but easses when warmed up, do you get that to??
daveyboy20
Mon Dec 10, 2007 4:23 pm
Its much better when warmed yep, but it doesnt crunch (yet!)
Dave_M3
Mon Dec 10, 2007 5:06 pm
I doubt it's a scyro imo anyway since its better when moving and only problematic when at a standstill.
Sychros are for swapping cogs when the car is in motion.
cypriot_boy_2k7
Mon Dec 10, 2007 7:29 pm
mine crunches when changing :eek:
