how to reset service lights
rossmc88
Tue Nov 27, 2007 6:22 pm
is it possible to reset the service lights without taking the car to a bmw garage?
ive been searching on here for an hour cause i thought its prob been answered before but i cant find the answer anywhere.
cheers
Ross
eko
Old timer
Tue Nov 27, 2007 6:25 pm
tomze30
Tue Nov 27, 2007 6:26 pm
reaz12345
ye go europarts and buy a service re set tool for £20 use it as offen as u like :cool: :cool:
kam-325i
Tue Nov 27, 2007 6:30 pm
Google is your friend dude......
rossmc88
Tue Nov 27, 2007 6:36 pm
thanks for the replies
i searched for stuff like reset service lights but nothing came up
thanks again anyway :mad:
jcjdavis1
Tue Nov 27, 2007 10:53 pm
bazcoupe
Tue Nov 27, 2007 11:30 pm
make sure you do a service first though or else its cheatin :wink:
TRANSPORTER
Wed Nov 28, 2007 11:19 am
Try GSF my mane £12.95 for a reset tool just follow the instructions that come with it and hey presto all oyur lights are back on. But as bazcoupe has said make sure you do a service if only for your own peice of mind.
THERE ARE AIMERS, USERS, MOTORISTS AND THEN DRIVERS
jbh
Hartge Crew
Wed Nov 28, 2007 11:50 am
ross ive got the tool here to reset the lights :wink:
Wed Nov 28, 2007 7:31 pm
jbh wrote:ross ive got the tool here to reset the lights :wink:
So have I! It's called six inches of wire.
TRANSPORTER
Thu Nov 29, 2007 9:00 am
And here I was thinking you were a mega sympathetic mechanic who uses all the right tools for the right jobs Brianmoooore :eek:
daveyboy20
Thu Nov 29, 2007 11:11 am
If the lights aren't on at all does that mean it needs a service? I thought mine was broke as there are no lights whatsoever. I have a reset tool found it in the boot but it was a bit wet. I ve dried it out now should i risk using it? Cheers
**BANNED**
Thu Nov 29, 2007 11:46 am
When you first switch on the ignition do any of the service indicator lights come on?
Youth is wasted on the young.
Nelly
Gumbo
Gumbo
Thu Nov 29, 2007 6:26 pm
As Brian mentioned, 6" piece of wire - into pin number 7 and earth it to a suspension turret nut - turn ignition lights on and weight for the lights to reset.
Do the same for the "inspection" + the clock face symbol.
"I F**KING LOVE YOU GUMBO"
daveyboy20
Thu Nov 29, 2007 7:05 pm
No theres no sign of life at all, the mp meter thing does nothing wither just sits to the left od the guage - could it b inked?
Thu Nov 29, 2007 8:07 pm
The LEDs and small bulbs are on a seperate small plug in circuit board, so if there are no lights at all, the chances are that the board has been removed to put the lights out.
It's not unusual for a faulty econometer to swing from one side to the other. Are you sure yours just stays on the left?
daveyboy20
Thu Nov 29, 2007 8:21 pm
Yeah just stays to the left, off the scale! doesnt ever move wether engine is on or off. Is it easy to get behind there to check the service light chip?
Thu Nov 29, 2007 8:52 pm
You need to remove the cluster and open it up to get at the SI board and its daughter board.
I think how is in the tech articles.
