Changing the big Diff bush/ + CENTRE PROP BEARING?!
Yo! Need to do mine before i go to the ring so any tips? my dad has a press at work but the back plate looks like nice and brittle aluminium.
So i fear it would be all to easy to break?
Cheers Si
Cheers Si
Ant
- Retired Team Member
Simon, the backplate is indeed a lil fragile, the bush only goes one way, the "hole" is slighty oval so no probs there, use the Z3 bushing as its a stronger design, go MZ if your wallet can stand it.
remove backplate,
gently warm the area surrounding the bush with a blowlamp.
use the new bush to press the old one through, can take 5 tons to get them moving though, I've seen higher on a couple without problems, the heat is the key dude.
If you want me to do for ya no worries, bring the bits and I'll do the honours
remove backplate,
Email FTW
Andy335Touring
I'd change it to the Z3M coupe bush rather than a standard E30 one.The coupe bush has got less cut outs/more rubber and metal ribs so makes it a bit stiffer.
Sorry i can't help with changing it,i didn't have access to a press so i took it to the garage to swap whilst the dif was being swapped from 3.25 to 3.64 ratio.
cheers guys, i have bought the ZM3 one as it was Ԛ£3 more than the normal E30 one, so it was rude not too! plus the 10% they give me for being a pest there!
martinclan
I did mine without a press. I cut out the rubber inner then CAREFULLY hacksawed through the metal part so that it was ALMOST cut through. Then a few sharp tap with a hammer and cold chisel and out it popped - no drama. Make sure that the backplate is well supported though.
The new bush was easily tapped back in once I had gently cleaned up the hole where it goes.
It's an E30 Jim but not as we know it...
buster
cheat and do what i did,replace it with a zm coupe cover !
jamie325isport
Nice one, how much was that then Buster? Also bit off topic i know but been meaning to ask for a while, what did you do to get the twin exit? They are both connected i take it. Was it an old E21 323 system? and does anyone know if they can be made to fit? (i know i will start a whole new thread)
buster
Ԛ£100 at the $tealer for the diff cover.
The exhaust;
i bought a e46 m3 back box.
then realised even with a bit of chopping it weren't going to fit !
I ve still got it in the shed !!
I then noticed ,twin exhausts could be fitted but would need to be further appart than in the pic to fit either side of the tyre well.I didn't like the look of that though i wanted them closer in.BUT this can't be done without chopping the tyre well out,so i never.
The pic is a photoshop chop !! its a fake ! Id love it to be like that ,maybe one day i might do it.
The exhaust;
when i change my centre prop dohnut thingy can i get the prop off at the diff end?! so i can do my diff bush at the same time?
Jos
I would recon you will have to drop the diff out to change the bush on it. Should be no issues getting the prop undone from either the box or the diff, the nuts on the guibo are quite tight though, do the diff end 1st using the gearbox to keep it inplace while you slacken them.
Nice idea on the Z3M cover, need to change my cover as its from an e23, and it's finned too!
'94 e36 tree climber
95-540iLE
- Zone Newbie
I know this is an old thread, but does anyone have the part number for the ZM finned cover bits?
buster wrote:cheat and do what i did,replace it with a zm coupe cover !
oze30
95-540iLE
- Zone Newbie
oze30
Though I'd check with BMW when youorder it.. Im not sure if the ones in teh diagram are finned!
The appearance of the cover in the ETK diagram may, or may not, bear any relation to what it looks like in real life. The diagram is just for identifying a diff rear cover.oze30 wrote:Though I'd check with BMW when youorder it.. Im not sure if the ones in teh diagram are finned!
Chris-W
Eg. M3 bodyshell shown without flared rear arches, etc.Brianmoooore wrote:The appearance of the cover in the ETK diagram may, or may not, bear any relation to what it looks like in real life. The diagram is just for identifying a diff rear cover.oze30 wrote:Though I'd check with BMW when youorder it.. Im not sure if the ones in teh diagram are finned!
