Special Touring Fenders?
KDS
Post Wed May 11, 2005 8:30 am
My Touring has the standard black plastic rocker trim that seems to be exclusive to Tourings. When I pulled off the short front segments I found rust hiding underneath on both fenders.
Rather that do a repair, I'm planning on just ordering new replacement fenders. My question is, do Tourings have the EXACT same front fenders as all other E30s? Because there are all sorts of special clips and plastic rivets that hold the rocker trim on, I'm worried that there might be some subtle difference.
Anyone have experience?
-KDS in Vancouver ('88 325i Touring)
Nelly
Gumbo
Gumbo
Post Wed May 11, 2005 9:05 am
Hello KDS, i'm guessing that fender = bumper but what do you mean by plastic rocker trim? any pics would help alot. If it's the panal under neath the front bumper it's really easy to remove/replace these as their bolted in with no welds anywhere.
Post Wed May 11, 2005 9:08 am
IIRC, rocker = cill
Nelly
Gumbo
Gumbo
Post Wed May 11, 2005 9:15 am
Or, fender = front wing. If so then yes these are the same as saloon shape ones, the only two that you can't use are the cabby ones (little bit longer) and the M3 ones for obvious reasons. Same again with the wings, remove all plastic inner arch protectors, remove front bumper, remove all screws from the wing ie; all along the bonnet edge, above + below the lip under the head light, some where the bumper ends and lastly not forgetting the two that are located inside the wing where the door hindges from. Then lift the wing off the car being carefull not to bend it.
Hope this helps you out mate, Neil.
astondg
Post Wed May 11, 2005 9:59 am
I think:
Fender = wing
hood = bonnet
rocker = sill
Aston
BMW E30 323i with some stuff
1:21.67 @ Morgan Park Raceway
KDS
Post Wed May 11, 2005 6:35 pm
Okay, okay, okay! Sorry for all the North American speak.
As Nelly guessed, fender=wing. By rocker trim, I mean the black strip that runs along the whole length of the car, below the doors, between the wheel arches.
So, back to the original question: are Touring wings slightly different in order to accomodate the "rocker trim".
Nelly
Gumbo
Gumbo
Post Wed May 11, 2005 7:00 pm
After all that - - - - no, you'll be fine if you don't use cabby or M3 trims.
Post Wed May 11, 2005 9:30 pm
You'l have to drill a couple of 10mm? holes in each wing (fender), but otherwise they are the same. Same applies to the cills (rockers).
KDS
Post Wed May 11, 2005 9:34 pm
Thanks gang!
Richy325iTouring
Post Wed May 11, 2005 11:46 pm
astondg wrote:I think:
rocker = sill
Aston
Cill :cool:
soz but i pick builders up on this all the time
i just couldnt help myself
Jos
Post Thu May 12, 2005 12:14 am
No it's 'sill' :lol:
Construction tends to use 'cill' for some reason :) :mad:
'94 e36 tree climber
Nelly
Gumbo
Gumbo
Post Thu May 12, 2005 8:26 am
LOL, fight fight fight!!!!
Worker against Foreman??? who will win?
PS - glad your all sorted now KDS,no worries about the help - the pleasure is all ours at the Zone.
