I've got some spacers to fit to the front of my e30 once my e36 rack goes in and I shim it up for some more lock.
I know standard bolts are m12 x 1.5, whats the standard length as the spacers are 10mm and I need bolts roughly that extra. If no-one knows there some on ebay is the measurement of the thread or whole bolt?
Wheel Bolts
BadDave
Standard length is 50mm dude
M12 x 1.5mm as you already know
HTH
Dave
HTH
Dave
Templ8e30
Standard E30 length is 30mm, measured from the end of the bolt to the bottom of the taper.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
BadDave
Should have said the the 50mm is total length
