diff options
E30Mark
How much power?
5 seriers diff won't fit (internals might)
Double check the diff mounting point to the chassis, not uncommon for these to rip off the chassis! - also make sure your sub frame mounts are new.
Can't see you'll gain much in strength between a 320 / 325 diff just different ratio's, unless the 320 is a small case??
PM for details
PM for details
- **BANNED**
Two sizes of diff cases are used on E30's.The small one(6 bolts to the rear cover)went in the 4 pot cars and most 230's.The medium case diff(8 bolts to the rear cover)was used in all 325's.Both came in a multitude of ratios and open/LSD.The medium case unit was also fitted in E28's,which opens up the ratio range still futher.An ex E28 diff will need it's output flanges swopping to fit the narrower E30,however.Use a Z3M diff mounting bush.
Youth is wasted on the young.
