Apologies for being a numpty, but which wires do I have to cut/splice for the OE unit. Are these the wires for the socket which the relay plugs into? Just thought I'd check before I commence butchering of my car!
Brianmoooore wrote:To make the E30 socket ready for a delay relay, you have to find the brown/purple behind the driver's speaker, which goes from the interior lights to the pin switch (-ve side of courtesy light) and remove it from the pin switch.
Taped up to the loom nearby, you will find a brown/yellow wire with a female spade connector and a brown/purple wire with a male spade connector.
Push the brown/yellow onto the pin switch, and join the two brown/purples together.
If using the OE BMW unit without the door switch, you have to cut the brown/green wire a couple of inches from the socket and splice it to the brown/yellow wire.
