Wipers gone mad
Simon
Mon Aug 06, 2007 9:27 pm
Ignition on, and they automatically go onto a fast wipe without being switched on, tried changing the relay to no avail, any ideas what could be causing this?
zimmerbimmer1
BMW Parts Meister
Mon Aug 06, 2007 9:49 pm
check the switch on the column. might of come adrift inside causing to go to fast wipe.
Simon
Mon Aug 06, 2007 9:50 pm
Nothing wrong with the switch, it's only a couple of years old, and this has only happened since the battery has died, and the car has been jump started after not being run for a couple of months.
316eyes
Mon Aug 06, 2007 9:55 pm
Sounds like a short on the motor if it runs permanently. If you have a spare one plug it into the connector and see if it works OK.
I'm not completely perfect.......there are some bits missing or broken.
But the weather here helps!!!
Mon Aug 06, 2007 9:56 pm
Assuming the wipers stop when the 'relay' is removed, the problem must be with the column switch, or the wiring between it and the 'relay'.
Simon
Mon Aug 06, 2007 10:09 pm
Yes, wipers stop when the relay is removed, I will try fitting another stalk to see if this makes a difference..
murran
Wed Aug 08, 2007 8:06 am
does the relay click when you pull it out of the board and again when you plug it back in? sure its not the fuse board?? i had a similar prob with my mk2 golf, the fuse board was corroded and shorting out inside cus there was water dripping on to it when it rained from the leaky windscreen seal!!! :o
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
