How many flexible brakes hoses on a 325 (1987)?
I've just bought new flexible front hoses from ECP for ~Ԛ£10 each, but been quoted ~Ԛ£12/each for Goodridge# hoses from Merlin Motorsport, and Ԛ£41 for a set (4 lines).
I'm thinking I should take back the std hoses and buy the set.....
I thought ABS cars had 6 lines?
Mark
# ECP siad Goodridge didn't do hoses for an E30.
brake pipes?
jumare
ian332isport
Should be 6jumare wrote:How many flexible brakes hoses on a 325 (1987)?
jumare wrote:# ECP siad Goodridge didn't do hoses for an E30.
Twats...
Jos
Should be 6 regardless of ABS, 2 on the front, 2 on the rear and 2 on the trailing arms.
SBW0012-6 BMW 316-325 (E30) 82-91 (ABS) (NOT 323)
as far as I can tell this is the set
SBW0011-4 BMW 316-325 (E30) 82-91 also listed, but only a 4 hose kit.
'94 e36 tree climber
jumare
Having looked at the ETK now I understand, 6 hoses but still only 1 hose to each caliper.
Having got the ECP hoses home when you screw them into the caliper the hex part isn't flush with the caliper, are there different hoses for the different calipers?
Is SBW0012-6 the Goodridge P/N?
Mark
Mark
jumare
Ignore that bit so do the old hoses....jumare wrote: Having got the ECP hoses home when you screw them into the caliper the hex part isn't flush with the caliper, are there different hoses for the different calipers?
Jos
Yep, looks like it, SBW0012-6-SS are the stainless ones, so I assume the ones without the -SS are the standard ones.jumare wrote:Having looked at the ETK now I understand, 6 hoses but still only 1 hose to each caliper.
Mark
