Leaking Gearbox oil 325i manual 1991
Spankie
Fri Jul 13, 2007 9:42 pm
Hi all, just bought the car and its dripping gear box oil, and interior stinks of hypoid! The strange thing is that the oil seem s to be comming from above the rear bearing seal, book says theres a vent??? is it likely to be that or the gear selector shaft seal? I cant seem to see either from below, woukld like some past expeience advice bfore I remove exhaust and propshaft...will it be a gear box out job? many Thanks :)
zimmerbimmer1
BMW Parts Meister
Fri Jul 13, 2007 10:24 pm
I reckon on the selector shaft seal, think the cost less than £5.
Gearbox out would be easier but I think you can do it in situ.
Spankie
Fri Jul 13, 2007 10:30 pm
Thanks, will try and change it, looks a 'b' Cheers.
Templ8e30
Fri Jul 13, 2007 10:48 pm
Screw in a brass woodscrew between the shaft and the seal then pull it out with a pair of pliers. The brass won't damage the surface of the shaft :D
The hardest bit is getting to it.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Spankie
Fri Jul 13, 2007 11:05 pm
Thanks for the Tip, reading some other articles i'm thinking it mighty vbe a good time to also fit a quick shift are they any good?
