touring headlining
Cloggy Saint
Sat Jun 16, 2007 10:54 pm
I've done a search on this but am still unsure about a few things. Is the headlining just fabric stuck to foam, or is it fabric, foam and a hard backing? Can I somehow just drop the front of the lining to give me access to the roof aerial mount?
HairyScreech
Sat Jun 16, 2007 11:06 pm
iirc its lining/foam/hardboardlikestuff. as it isnt the same as a saloon one and requires more support to keep it up.
Cloggy Saint
Sat Jun 16, 2007 11:13 pm
Are there any parts of it tucked under the front screen?
old_skool
Sat Jun 16, 2007 11:20 pm
datourer wrote:Are there any parts of it tucked under the front screen?
No, not as far as I remember.
zimmerbimmer1
BMW Parts Meister
Sat Jun 16, 2007 11:26 pm
No it is not tucked under screen it is clipped at the front be careful if you pull down to far it will crack or break
Cloggy Saint
Sat Jun 16, 2007 11:41 pm
cheers, I envisage a shiny new aerial mount and a knackered lining!
oze30
Mon Jun 18, 2007 8:54 am
If its the ariel mount, you dont need to drop the lining. Its an 8mm nut on top. Just remove the ariel and the prise apart the 2 p;lastic halves. Then undo the nut and the mount should come free.
Cloggy Saint
Mon Jun 18, 2007 5:29 pm
unfortunately my aerial mount is one piece, non adjustable.
oze30
Tue Jun 19, 2007 12:55 pm
In that case.. now would be a good time to upgrade to a black sport headlining. The sunroof motorbracket needs to be dropped to get the cable past ( pending if it's been done properly when it was replaced)
less2303
Tue Jun 19, 2007 12:58 pm
oze30 wrote:In that case.. now would be a good time to upgrade to a black sport headlining. The sunroof motorbracket needs to be dropped to get the cable past ( pending if it's been done properly when it was replaced)
Would a black sport headlining from a saloon fit a touring then?
Tue Jun 19, 2007 9:28 pm
Think you'll find there's a big hole at the back!
oze30
Wed Jun 20, 2007 9:06 am
The sunroof console.. not the dodgy flimsy black thing!!!
KDS
Thu Jun 21, 2007 5:00 am
The good news is that the black factory headliner is still available for the Touring. The bad news (if you have a sunroof) is that the sunroof panel is NLA. Argh! Ask me how I found out. ...And before you get all clever and think you can just order the black panel from an E30 M3, the fabric is not a match. Double-argh!
I just ended up taking my car to an upholstery shop and they stripped and re-skinned the whole thing in swanky black cloth. Not an exact match to the factory item, but it looks great and is MUCH more affordable.
-KDS in Vancouver ('88 325i Touring)
SPADGE
Thu Jun 21, 2007 8:13 am
Col is refering to the black console thing that the visors attach through not the headlining itself.
All the roof aerials i have seen are held on with the 8mm nut which is on the outside under the plastic cover.
Simon
Thu Jun 21, 2007 9:51 am
The black visor panel is a straight swop, and makes a great improvement to the crappy touring one. Did mine when I first bought it.
E30's on the continent do have different aerials, my M3 came with one when I bought it, but the end was snapped so I bought a new standard one.
You can see the aerial on Playos car in this pic, towards the rear...
Hutch4161
Sat Sep 15, 2007 10:11 pm
Hi
My headlining on my touring is also drooping at the back and is a crappy cream colour, I am thinking of removing it and putting glue on the saggy bits, then giving it a coat of black spray, anybody done this before ????
Cloggy Saint
Sat Sep 15, 2007 10:19 pm
There's a similar thread going on here
I know people who have said a headlining can be painted but i've never seen pictures. My headling is currently held up by a load of drawing pins. It looks great :(
oze30
There's another thread on this. Do a search for headlinings in the chat section.
