Im losing fluid and have no idea where , Any ideas guys , I bled the system when i put the slave cylinder on and im lost on what to do
Help , Clutch problems
Have put a new master cylinder and a slave cylinder on the e30 and last night the reservoir where its topped up was nearly empty again
Giggety Giggety Goo!!!
Martinaston
When you put the new master cylinder on was it an aluminium or a steel one ?
There is NO nucleus.
Cant remeber mate as one of the guys at work fitted it , Have checked for leaks and cant see any , Does the slave sit flush to the gearbox or is there a very small gap , As the old one was caked it crap and when the new one was fitted it sits on the gearbox ok and bolts up fine but the nearside has a small gap , Im talking approx 2mm ??
