How does the throttle pedal come out of the floor? Want to tackle a carpet change but dont want to break the hinged part of the pedal. Can't see any bolts through the floor from underneath either.
When I took the new carpet out of the donor car i jus snapped the pedal off at floor level. Don't want to do that now though.
Accelerator Pedal removal.
- Brianmoooore
It's not actually intended to be removable without breaking it, but will usually pull out if rocked from side to side.
- Brianmoooore
No; you simply ask your dealer for a new one.KDS wrote: And if it does break, are you completely screwed?
Car is still completely drivable without it. I've done it many times when the carpet has been out for some reason or other.
