The engine oil light in the overhead check control comes on after I have been driving for about 10 mins.
I have checked the oil level as its fine, nearly full.
Does anyone know what else could cause the light to come on?
OHC Engine Oil Light Problem
- **BANNED**
At what engine speed?
- **BANNED**
Sounds like no oil pressure
Is it using oil
kam-325i
- Contact:
The OHC oil check light is for Engine oil level, not oil pressure.daimlerman wrote:Sounds like no oil pressureIs it using oil
Maybe removed the sensor and soak it in some turps/petrol over 24/48 hours to clean out any gunk.......
- **BANNED**
Ah,are we talking about the oil level light in the top check panel
kam-325i
- Contact:
Maybe a dirty/knackerd sensor. take it out and give it a good clean.....
- **BANNED**
Sorry,I will get an eyesight test,failed to read the OP.If its not the sensor,is oil returning to the sump
The external pipe under the inlet manifold...
kam-325i
- Contact:
The external pipe under the manifold is not for "Oil Return To The Sump"daimlerman wrote:is oil returning to the sumpThe external pipe under the inlet manifold...
Its part of the PCV system.
- **BANNED**
Backs off muttering theres a big hole in the camcase valley with a pipe down to the sump.
kam-325i
- Contact:
There is yes, but its for crankcase gases to vent into the head/cam area, which in turn vent into the intake manifold. The oil return path is on the exhaust side of the head.daimlerman wrote:Backs off muttering theres a big hole in the camcase valley with a pipe down to the sump.
