leaking antifreeze
wise
Sun May 06, 2007 2:31 pm
hi. im leaking antifreeze on to my n/s/f footwell on my 325i sport, only a few drops once in a while. what are the posabilties it could be. cheers
gazza
Sun May 06, 2007 2:41 pm
seals gone on the end of the heater matrix check up under the dash ....common on e30,s new seals are cheap
wise
Sun May 06, 2007 2:53 pm
easy to fit? cheers
gazza
Sun May 06, 2007 4:36 pm
no but it can be made easier by loosening the master cyl/servo(4 bolts) and removing the glove box and under trim
danthe had some good pics on here a couple of months ago do a search on heater matrix and his name danthe
and it could be to your benefit but the seals are pennies but when you see the position of the screws you will know what i mean
Sun May 06, 2007 5:06 pm
More likely to be the electric valve.
Have you checked that you have the replacement pressure cap that should have been changed years ago under a safety recall?
