Ruuuuuuussssssttttt....
Royalratch
Fri Apr 27, 2007 4:58 pm
Found some spots of rust on my Touring. Nothing serious, the odd bit on the tailgate and tinges on the front valance.
What's the way to do this?
I was going to scrub it all of with a steel brush then spray on some inhibitor? It's in areas that aren't seen anyway.
Or is this a bodge.
aceraf
Fri Apr 27, 2007 6:00 pm
If you do that, make sure you paint over it within about 3 hours i think it is! (sure that's what they recommend)
Oh, and make sure you've got all the rust removed....are you using some of that rust treatment stuff that makes the metal go black wherever it comes into contact with rust (can't remember the name...think Loctite make some)?
Breaking 325i Touring
aceraf
IF they're accessible, you could shot blast them (very messy!)
tylerma
Fri Apr 27, 2007 6:01 pm
just stick your IS engine in and the rust will disappear lol
just kidding Ratch
Royalratch
Fri Apr 27, 2007 6:17 pm
tylerma wrote:just stick your IS engine in and the rust will disappear lol
just kidding Ratch
:D I'm hoping that will get rid of most of it!
But for the stuff the M42 does not shift, yes I'll use that contact stuff then paint over that - but with what?
Want something hardcore.
russ325i
Fri Apr 27, 2007 6:43 pm
aceraf wrote: that rust treatment stuff that makes the metal go black wherever it comes into contact with rust (can't remember the name...think Loctite make some)?
Pretty sure it's called 'Kurust' (a play on cure rust, something like that..)
bigkev
Fri Apr 27, 2007 6:49 pm
try this stuff its ace just dont let it dry out (keep it out of the sun)
http://www.bilthamber.com/deoxgel.html
pnd
Fri Apr 27, 2007 6:57 pm
If you are going to use that Kurust several applications are advisable also have a bloody good look round cos there will almost certainly be some rust elsewhere too.
Royalratch
Fri Apr 27, 2007 7:02 pm
What to put on after guys?
munky30
100% Pure Council
Fri Apr 27, 2007 7:24 pm
paint? Lacquer?
Hammerite.
aceraf
Fri Apr 27, 2007 8:59 pm
rub down any bits that are visible, and then colour code them.
bigmattpowell
Sat Apr 28, 2007 7:40 am
After rust killer/kurust etc. try "Hammerite number 1 rust beater". Grey/beige primer and it's fine to rub down and paint over. Normal hammerite is too sticky to put anything over.
