funny noise getting louder!!
- Brianmoooore
Never heard a fuel pump hiss! Probably an exhaust leak if it starts with the engine.
john325tewerin
Are you hearing it when you're inside and outside of the car?
Ziggy
Well no, but it's kindof a hissy whiney noise, no? I'm rubbish at describing noises anyway!Brianmoooore wrote:Never heard a fuel pump hiss! Probably an exhaust leak if it starts with the engine.
- Brianmoooore
Hissy whiny noise sounds like the diff, but that won't start until you're moving.
Ziggy
True... I've had both, so my lack of skill at describing a noise is probably compounded by not actually remembering what a noisy fuel pump sounds like!Brianmoooore wrote:Hissy whiny noise sounds like the diff, but that won't start until you're moving.
I'm fairly sure I know what the answer's gonna be, but do any of the snake-oil type things actually work on noisy (input shaft bearing I expect?) diffs? & can you use em with LSDs?
Speaking of snakes, maybe you have a dehydrated Boa-Constrictor trapped under the back seat...
john325tewerin
Sounds like you need to tune your radio
