Fitting a towbar
martinclan
I have acquired an original Westfalia towbar for my E30. Can anyone tell me what is involved in fitting it - is it a straight bolt on job or do I have to drill any holes?
Robin
Robin
It's an E30 Jim but not as we know it...
Templ8e30
I've got one and need to fit it to my new touring
You need to drill 4 more holes in the rear panel for the brackets (they are just above the existing bumper mountings and are marked with a centre punch), 4 on the boot floor and one more for the electrics.
The rear bumper needs cutting for the swing down electrics socket to work.
I'm sure there's some fitting instructions somewhere, I remember seeing them but I can't find them on my PC
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
martinclan
Anyone else have a set of fitting instructions?Templ8e30 wrote: I'm sure there's some fitting instructions somewhere, I remember seeing them but I can't find them on my PC![]()
Cheers,
Iain T
Robin
I have the genuine BMW fitting instructions for a towbar. It's a towbar that appears to consist of a beam mounted inside the bumper, using the bumper mounting points. Does that sound like yours?
It's a 37 page pdf.
It's a 37 page pdf.
Templ8e30
That sounds like the one, it's the one with the removable tow ball.
Cheers,
Iain T
Cheers,
Iain T
martinclan
That's the one! Any chance that you could email me a copy? PM sent with good email address....Brianmoooore wrote:I have the genuine BMW fitting instructions for a towbar. It's a towbar that appears to consist of a beam mounted inside the bumper, using the bumper mounting points. Does that sound like yours?
It's a 37 page pdf.
Robin
Will do it tonight! Remind me if I forget!
Renton500
Hi Brianmoooore, can i have a copy of that fitting giude too pls if i pm you my email address?
martinclan
Reminder.....Brianmoooore wrote:Will do it tonight! Remind me if I forget!
Sure! Are both cars post facelift, as there's a different set of instructions for the chrome bumper stuffRenton500 wrote:Hi Brianmoooore, can i have a copy of that fitting giude too pls if i pm you my email address?
martinclan
Hi Brian
Yep - mine is an '89 318is.
Robin
Robin
Templ8e30
Brian, mine's a facelift too.
Email addy PM'ed
Thanks a milion mate,
Iain T
Email addy PM'ed
Iain T
Sure. PM away!Renton500 wrote:Hi Brianmoooore, can i have a copy of that fitting giude too pls if i pm you my email address?
Templ8e30
Thanks Brian
Cheers,
Iain T
Cheers,
Iain T
LowLevel
Does anyone have the .pdf for installing the Westfalia towbar?
I need it!!!
I need it!!!
-AJ
