Removing the rear diff fixing bolts?
s1oww
Any tips at how to remove the top 2 19mm bolts holding the diff in place as they look a sod to get at?
Chris-W
Ziggy
Ring spanner on nut, scaff pole on spanner.
s1oww
Cheers, It will have to be a 2 spanner job as i dont have a flexi ratchet or scaff pole.
I'm off to do it in a min, i have a feeling im going to loose most of the skin on my hands, fun fun fun
DRIFTBOY
Ring spanner and a piece of exhaust pipe my favourite method.
If not, ring spanner and a club hammer!
E30Mark
Ring spanner, then lie on your back and push it with your foot!
PM for details
PM for details
Templ8e30
I've got an extra long (400mm) 19mm combination spanner that comes in handy for cracking these bolts loose.
To get them all lined up when re-fitting I screw in the lower 2 bolts first then use a spare mirror glass to see when you've got the top 2 lined up. Fit the single bolt through the rear cover last as it lifts the whole axle assembly into place.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
clubfx2
I did this just yesterday... And its not a 1 hour job to switch diffs... Especially the first time...
Use lots of releaseing spray before attempting, mine was nice and gummed up with some corrosion.
I used my normal socket set, bit tricky to get in place, but you need a good secure fitting on the bolt heads. Lots of might behind it too, screwed bleeding tight...
Good luck!!!
Give us a shout if you get stuck?
Good luck!!!
Regards
Clyde
Go everywhere sideways...
Clyde
s1oww
All done, at 2.46am. It took forever to get everything lined up. Lovely weather too as we couldnt close the garage door. We snapped a few tools and my hands are killing, but she goes round now
Templ8e30
Bitch of a job isn't it ?
My diff has been swapped so many times now everything comes off with ease, no rusty crusty nuts and bolts
It started life with a small case 4.1, then a medium case 3.64, then a 3.91, then a 3.73, now it's a 3.91 slipper
Cheers,
Iain T
Cheers,
Iain T
