Post
Sun Mar 04, 2007 11:38 pm
The motor mechanism can get damaged, but this usually results in teeth jumping on the rack and pinion gears, rather than weak motion.
Problem is probably in the door pillar plug and socket, but can be either the passenger or driver's door, since the signal goes through both.
There should be 12 volts at the black wire of the mirror motor all the time the ignition is on. (check with a 12V lamp, not a meter). Earthing the blue wire should make the motor move.
Don't touch the mirror switch while doing this!
