Rear Wheel bearing, help
J_Mac
Post Sat Mar 03, 2007 5:55 pm
i've got everything out and off apart from the outside of the wheel bearing itself, all the ball bearings came out when i hit it with a hammer, only thing left is the outer bit, i've tried everything i can think of and haven't got a "puller" tool .. any help at this point would be great as my cars in bits
ric325i
Post Sat Mar 03, 2007 6:03 pm
dude thats bad news.
i have just got in from changing my front wheel bearings! couldn't buy the the wheel bearing so had to buy the hub.
£120 each from bmw
£70 each from another place i thought waw cheap
£80 for both at euro car parts :cool:
all the haynes said fro the front was tab with a hammer but it sounds like you have tried that.
it has too come off! just unleash a the sledge hammer on it :twisted:
stuartgallafant
Post Sat Mar 03, 2007 6:06 pm
the best way of removing rear wheel bearings is with a slide hammer. in fact, insitue, its the only way!
if i'd known you was gonna do this, i would said you could drop the car upto me and i'd do it for you!
ric325i
Post Sat Mar 03, 2007 6:11 pm
i have just been looking at the slide hammer things and i dont have a clue how they work?
how much of a pain is it having to have the correct tool for the job :evil:
but i did buy a big breaker bar today :twisted: very useful
stuartgallafant
Post Sat Mar 03, 2007 6:50 pm
slide hammers are easy to use!!
you just attacht the plate on to the hub, then attach the slide shaft inside the plate, then using the slide throw, just hammer away until you pull the hub off. then undo the plate/hammer and then put the other little bit behind the bearing and use the same action as before
Andy335Touring
Post Sat Mar 03, 2007 7:01 pm
Have you got a Dremel with a small grinding bit ?
Care fully grind a grove through the race, it will ping/crack then it will tap off easy.
ric325i
Post Sat Mar 03, 2007 7:04 pm
Andy335Touring wrote:Have you got a Dremel with a small grinding bit ?
that sounds better than attempting the self love with your car (slide hammer)
J_Mac
Post Sat Mar 03, 2007 7:14 pm
its just the outside or the bearing, the case so to speak, it's ceased in there like i don't know what, and it's harded steel so grinding would be ok if i could get in thee but a jigsaw blade stood no chance, i tried.
wish i'd of said earlyer, stuart i would have took you up on your offer, i'm quiet stuck :x
J_Mac
Post Sat Mar 03, 2007 11:17 pm
ok had enough, it's late, cold, knees and arse is wet. I tried a compression way with 10mm thread 2 nuts a socket and a metal plate, with the socket at the back with the thread through it (nut on the end) the plate on the front (with the other nut)and tightened the 2 nuts untill........ the thread snapped, long ways! mayjor torque and no movement. If a wake up in the mood i'm in now the grinder will come out and won't go away untill it's out
stuartgallafant
Post Sun Mar 04, 2007 12:22 pm
J_Mac, i hate to be the bearer of bad news, but i reckon a slide hammer is the only way around this problem. that bearing has probably been in there since the car was built!
how did you remove the stub axle by the way? can you put any pics up?
how far is swanscombe from croydon? or warlingham?
J_Mac
Post Sun Mar 04, 2007 8:17 pm
done it thanks stuart, and just to answer your question not that far at all, about 20 miles give or take (my girlfriend comes from caterham)
I ended up disconnecting all the drum brake off and taking the trailing arm off, put upside down, socket on the back and a big sledge hammer later and it's out, not bad for a wanna-be mechanic/novice :D
(pisst whats the stub axle)
stuartgallafant
Post Sun Mar 04, 2007 8:27 pm
what a small world, my bird lives in caterham too! on the hill!!
anyways, i didnt realise you were doing it on a drum brake car... urgh!!
the stub axle is basically the hub at the rear of the car. if you have rear discs, you have a driveshaft, that will go through the stub axle, then a massive nut
number 1 in this pic
well done for doing though mate
if you ever get stuck or want some help or anything, drop me a line mate
J_Mac
Post Sun Mar 04, 2007 8:36 pm
indeed it is :) never thought it would turn into such a big job
thanks for the offer, no doubt you will hear from me again :wink:
(note to self, must get arse in gear and get up to the westerham meet)
stuartgallafant
Post Sun Mar 04, 2007 8:38 pm
J_Mac wrote:(note to self, must get arse in gear and get up to the westerham meet)
as far as im aware, you didnt miss much!!!
